Water Heaters Logo
Posted on Feb 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RUUD PVP75E-1 Gas Water Heater short cycling
Igniter is constantly lighting the pilot.
Gene Haynes
Level 3:
  • Water Heaters Master 5,391 Answers
  • Posted on Feb 02, 2013
Gene Haynes
Level 3:
Answers
5391
Questions
0
Helped
2603960
Points
14124
1) Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Otherwise Rheem-Ruud does not post service manuals
http://www.ruud.com/products/tank_water_heaters/gas_water_heaters/
3) Sound like bad gas control valve thermostat.
Newer Honeywell electronic controls can be replaced without draining tank.
Older mechanical controls are replaced by removal from tank after tank is drained.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2 Related Answers
BarrettDenCo
Barrett Palumbo
  • 1772 Answers
  • Posted on Dec 29, 2010
SOURCE: hi we have a Ruud
Sorry to read about your problem, I hope this helps you out.
you have a defective gas control, thats the big metal unit, with the dial on it, it needs to be replaced, no repairs can be made to it.
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Gene Haynes
  • 5391 Answers
  • Posted on Oct 07, 2012
SOURCE: Ruud PVP75E-IP Water Heater
Rheem-Ruud does not post service manuals.
Tank-type?
Copy following link to troubleshoot by type of gas control valve.
Tankless? Don't buy a tankless.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Why am I not getting a spark on the igniter of a 40 gal propane gas water heater?
Pilot could be blocked pilot injector is very small on lpg heater
May also need new Piso igniter sparker
Still can't find where you light the pilot light for the hot water heater on a self igniting factory installed heater on a 1997 Pace Arrow.
Generally, if a RV water heater is self igniting, then it is not designed to be lit manually. If you remove the outside vent cover door, then the unit can be observed. The self igniter should be visible at a point of where the pilot light is located. The problem with trying to light the water heater manually is that the circuit that activates the igniter also turns on the gas at the same time. If the igniter is not getting power, then most likely the valve to turn on the gas is not getting power either. If the problem is that the igniter itself has failed, then it may be possible, but unlikely, that with someone inside activating the turn on switch and a flame being applied to the pilot light area, at the same time, the pilot may light.
Self igniting hot water heater won't reset.
Today's water heaters have sealed combustion chamber and piezo igniter.
If igniter is bad, then water heater will not light... replace igniter.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
http://waterheatertimer.org/How-to-light-gas-water-heater.html
Gene h
Finally found the reset button on my Whirlpool hot water tank, but it will not budge when I push it. Why? Pilot will not light.
Reset button on gas water heater??
Usually there is not a reset button on gas water heater, which might explain why is doesn't move:
Do you mean the igniter button for lighting pilot?? The piezo igniter can go bad.
Copy following links for troubleshoot resources:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add comment with description of water heater, and more detail or call plumber.
Gene
h
Tank-type?
Believe I need to buy a Rheem Water Heater Thermocouple. Where do I find them?
If thermocouple is from ordinary tank-type water heater, then it is a generic part with different lengths 15" 17" 21" 24" 30" available at hardware of home center.
I suggest reading manual for installation information, advisories, and required maintenance.
http://waterheatertimer.org/pdf/Rheem-Ruud-water-heater-parts-guide.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
There are good utube videos on replacing thermocouple.
Tip of thermocouple has to be positioned in the pilot flame.
The heat on tip of thermocouple causes millivolts of electric current that travel back to the gas control valve and the electrical signal causes gas control valve to keep gas flowing down the pilot tube to the pilot light.
If pilot light blows out or if pilot tube is clogged and needs to be cleaned, or if gas valve has gone bad, then tip of thermocouple cools down and electric signal back to gas control valve causes gas control valve to shut off gas going to pilot.
When attaching thermocouple to gas control valve, it is finger tightened.
Be careful and do not cross-thread thermocouple. Just use your fingers to start the nut.
Finger-tighten thermocouple and then add 1/4 turn using small wrench.
The end of thermocouple has a small piece of insulation that isolates the electric current from body of gas control valve. If thermocouple is overtightened, the insulation is crushed, and electrical current millivolts short out and no signal reaches gas control valve, so gas control valve keeps gas turned off to pilot tube.
If this is a tankless water heater, then open following link with troubleshooting resources and contact information for Rheem.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Top Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Water Heater Expert? Answer questions, earn points and help others
