I m getting error for sql server 2005 when i connect it to my localhost, how can i get rid of this?
If you're trying to connect using "SQL Server Authentication" then you need to modify server authentication
If this doesn't help you then you can also take the help of this link to fix the error: About SQL Server Error 18456 And Its Solution
Have a look at below article:
http://www.katieandemil.com/microsoft-sql-server-error-18456-login-failed-for-user#lesscommon
SOURCE: Installing SQL server and VB.NET on VISTA Home Basic
installl SQL SERVER 2005
Vb.net is fine its your sql that will mess things up
BTW visual studio come with an SQL server
SOURCE: unable to add local server with SQL-Server Management Studio 2005
ok, you installed the management studio but did you install SQL server?
That is not part of the management product.
SOURCE: How to configure the sql server 2005
Enable remote connections for SQL Server 2005 Express or SQL Server 2005 Developer Edition
loadTOCNode(2, 'moreinformation');
You must enable remote connections for each instance of SQL Server 2005 that you want to connect to from a remote computer.
To do this, follow these steps:
Note Click OK when you receive the following message:Changes to Connection Settings will not take effect until you restart the Database Engine service.
SOURCE: i am unable to install sql server 2005 in windows
You can download Windows Server 2003 (SP2) from following link:
http://www.microsoft.com/downloads/details.aspx?FamilyID=95ac1610-c232-4644-b828-c55eec605d55&displaylang=en
Thanks.
