My condesner dryer heats and spins, but shuts itself off after 5 minutes. It will turn itself back on in 10-15 minutes, and I can restart it. But it will only run for another 5 minutes before shutting itself off again.
SOURCE: KENMORE DRYER
Hello ENRIGHT11
Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND
BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF
YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD
(ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal
of noise coming from the blower area of the dryer when it is running,
then the blower wheel could be defective.
The are many different
designs for blower wheels and just as many unique failure modes. Vanes
(fins) can break off the wheel and bounce around in the blower breaking
more pieces. The blower can break around the coupler with the shaft.
This can cause the blower to spin loosely on the shaft. The blower can
form cracks which cause it to vibrate, etc.
You should also not
be surprised to find foreign debris in the blower. The occasional
bird, rodent or squirrel has been known to bypass the out vent cover.
If they crawl into the exhaust tube the first thing they come into
contact with is the blower wheel.
If the blower wheel is not
spinning, or if it is missing vanes, it is not moving air efficiently.
As a result, heat is not removed from the heat source and it can trip
the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch
and/or become brittle with age. The belt can then slip on the drum or
motor to cause squeaking. If this is the case, the solution is to
replace the worn belt.
The belt is not the only item that can
cause squeaking. It can also be caused by a faulty idler pulley, worn
drum bearings, worn drum glides or worn drum rollers depending on brand
and style.
When replacing the Belt is is a good idea to also change the Drum
Support Rollers, Drum Glides, Idler Pulley and Clips. All of these
items are economical easily changeable when replacing the belt. The
upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some
dryer models are equipped with Drum Glides. The front of the dryer
rests on these glides. They provide a low friction surface on which
the drum spins. After time however, this glides wear down. Much like
an automobile brakes, these glides make a load grinding noise when they
wear thin. This griding against the drum usually leaves a bare metal
stripe that is visible at the point of contact. If the glides are
worn, the solution is to replace them.
The drum glides not
the only items that can cause squeaking. It can also be caused by a
faulty idler pulley, worn drum bearings, a worn belt or worn drum
rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the
Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these
items are economical and easily changeable when replacing the glides.
The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some
dryer models are equiped with a Rear Drum Bearing. The rear of the drum
rests on this bearing. It provides a low friction surface on which the
drum spins. After time however, this bearing will wear down. If the
bearing is worn, the solution is to replace it.
The rear drum
bearing not the only item that can cause squeaking. It can also be
caused by a faulty idler pulley, worn drum glides, a worn belt or worn
drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change
the drum glides, drum support rollers, drum belt, idler pulley and
clips depending on make and model. All of these items are economical and
easily changeable when replacing the rear drum bearing. The upside is
Worn Drum Support Rollers
Some
dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum
Support Rollers. The weight of the dryer drum rests on these rollers.
They provide a low friction surface on which the drum spins when in
operation. After time however, these rollers wear down. When they
wear, often times they begin to elongate and form a non-round 'cam'
shape. The result is that when the dryer is turned on it creates a
rumble that sounds as though you are trying to dry a pair of tennis
shoes. This sound is usually the drum being forced up and down on the
non-round wheels. If the rollers are worn, the solution is to replace
them.
When replacing the Drum Rollers it is a good idea to
also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips.
All of these items are economical and easily changeable when replacing
the glides. The upside is that your dryer will operate like new.
Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
SOURCE: Kenmore 70 series dryer shuts off and won't restart
IT SOUNDS AS THOUGH THE MOTOR IS OVERHEATING AND SHUTTING ITSELF OFF. THAT IS ABOUT THE ONLY THING ON THE DRYER THAT WOULD SHUT IT OFF AND NOT ALLOW IT TO START AGAIN RIGHT AWAY, BUT LET IT START AFTER A WHILE. MAKE SURE THE MOTOR TURNS FREELY. IT SHOULD NOT DRAG OR HUMM WHEN TRYING TO START.
SOURCE: Dryer runs for a few minutes, then shuts off
thermo sensor inside is bad (are you sure ALL vents and pipes are clear?)
SOURCE: gas dryer maytag MDG 7600 AWW Heats - then shuts off
Replace the coils READ THIS!!!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
