Acer Aspire 5742 Notebook Logo
Anonymous Posted on Feb 01, 2013
My acer aspire 5742 problem
My acer aspire 5742z shut itself down and wont go back on when i press on button the orange light with the bulb flashes and nothing else happens tried taking battery out and unplugging and holding on button to remove static but never made a differance.
pankaj rautela
Level 3:
Genius:
  • Acer Master 1,252 Answers
  • Posted on Feb 01, 2013
pankaj rautela
Acer Master
Level 3:
Genius:
Answers
1252
Questions
0
Helped
333356
Points
3358
Press it on without the battery if this does not solve then there is some fault in the motherboard of the laptop better take it to the technician
5 Related Answers
Anonymous
  • 17 Answers
  • Posted on Dec 29, 2008
SOURCE: Acer Aspire One 6 Cell Battery Problem
you got a bad battery. If your old battery works fine, and the new one wont hold a charge, Take it back to the store and get another.
benwabnick
Ben Wabnick
  • 2404 Answers
  • Posted on Jul 31, 2009
SOURCE: i have an acer aspire 3680 2682 that wont boot.
Try also taking out the hard drive and the dvd drive to make sure that they aren't shorting out the motherboard.
Also try another stick of memory besides the one that came with your laptop to be sure the memory isn't bad.
If after you do these steps you still can't get video then your motherboard is bad.
Anonymous
  • 155 Answers
  • Posted on Nov 27, 2009
SOURCE: My acer aspire won't power up
Try to connect your PC with the battery on the power outlet if it lights and charge normally. If the lights still orange, try to open the hard disk case and pull it out then try to put it in place again. If still doesn't go, try the memory card and clean it.
But I suspect that the battery has been overly charged. Try to look for another battery of the same model if it works with another and new battery.
Thanks
Johnathon Muise
  • 40 Answers
  • Posted on Dec 09, 2009
SOURCE: My Acer Aspire 5315 wont turn on?
remove the battery then try to turn on the laptop. if this works you probably have a bad/shorted battery
Fixitman909
Tommy Thomas
  • 430 Answers
  • Posted on Dec 10, 2009
SOURCE: Battery flashes orange when Acer Aspire D250 is off & disconnectd
flashing light is normal..when batt is being charged.....
My Acer Aspire x1200 desktop won't turn on. I press the power button, the fans rev and the lights flash blue as normal, then it beenps once and shuts down. It keeps cycling like this, trying to turn itself...
Have you by chance downloaded a new Service Pack for Windows?
Try booting into safe mode and doing a System Restore (if possible), if not try taking out your RAM Module(s) and re-seating them (it). If more than one try re-seating each one separately. One bad module could cause erratic behavior.
1helpful
Battery Wont Charge on my Acer Aspire One Notebook Orange light flashes when power on button is pressed I have checked that the charger is working fine but notebook won't come on as battery is so flat. I...
Try this:
Drain the static on the computer by removing the battery and the power adapter. then press the power button for 1 minute and release. Then plugged the battery back in and turned on the computer, if the computer won't come on plugged the Adapter back to the computer and try turning it on.
If problem persist it is possible that the battery already busted and you need a replacement.
Hope it would help.
2helpful
I was using mu Acer Aspire 7720G last night while
either plug in the back of the laptop is shot or you need a new hardrive
2answers
Acer aspire 9300 laptop
Right click anywhere on the desktop, open the screen saver tab, click on the power button at the bottom. You'll see a box that reads monitor, set this to never. That should take care of the screen shutting down. As far as the orange light, I'm guessing that's the battery light, and it's time for a new battery.(It should be green and flashes orange when the battery no longer works properly)
2answers
Cant shut down
keep start button pressed 30 seconds, the pc should turn off. If not brutally unplug the power cable. Do a scan disk on restart.
4helpful
2answers
Flashing Orange Light
the flashing orange light is an indicator to tell you that your wireless adapter is working and has a connection to your router, if you are not wireless, press the button that is flashing and it will dissable your wireless connection,to turn back on press it again.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
