I have a c2002 porter cable 6 gallon, 150 psi air compressor that is not putting out any air. The outlet regulator valve stays on zero. The tank pressure works fine. It cuts off at properly when the tank pressure reaches the factory set cut out pressure. I've tried turning the pressure regulator knob clockwise to increase the out pressure gauge, but still reads zero. What is wrong with my compressor?
SOURCE: I have a model FP209501 Air Compressor 2 Gallon,
The spray gun consumes more air volume than the compressor can deliver. You can pause painting periodically to allow the compressor to 'catch-up' or buy a larger delivered-volume compressor. The compressor that you have was intended to supply air for pneumatic nailers and staplers in an intermittent fashion. Hope this helps!
SOURCE: Tank pressure reaches setting but outlet pressure is not releasing air
if you have a air nozzle I would plug that in and see if you can get air out of that if no then you may have to adjust the hose/line pressure or you may have something inside that isn't allowing the air to come out of the tank in that case drain the tank and use either a small rod or peice of wire to poke through the outlet and clear it
SOURCE: No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
SOURCE: 25 gallon air compressor wont shut off,changed air regulator
You have a valve plate problem . It could be a slipped "o" ring to a bad reed valve. There are rebuild kits for that purpose. The kits include a valve plate assembly. It covers all the bases. When you look at this area pay attention to the partitions of the head gasket/"o"ring. You may avoid the cost of the kit.
SOURCE: Cambell Hausfeld FP2028 Compressor - What is the regulator knob?
It is generally above the air outlet where the hose connects?
