This is known as a BIOS password. If you bought the pc 2nd hand you should ask the previous owner for the password. If you have physical access to the motherboard itself, reset the CMOS by taking out the battery in the motherboard.
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
In case of your HP Elitebook laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
You cannot bypass the BIOS password, but you can reset the password. To reset the BIOS password read the information from this link.
In case of your Dell laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
I don't know how to tell you in spanish but this is how you do it
Step 1 Turn on your PS2 and choose the menu screen where you would normally enter the password. Instead of entering a password, go to the DVD setup menu. Go to "custom setup" and choose "parental controls". Step 2 When you are asked for the code or password, press the select button on your controller and enter the number "7444". Now set the parental lock to "off". Step 3 Press "reset" on the front of the game console to save your settings. When the system reboots, you should be able to view your previously censored games or DVDs. You will also have the opportunity to choose your own password, allowing you to turn the parental lock on and off, either manually or automatically by game or movie ratings. I often recommend that the parents of older children should regularly reset the password in order to prevent "hacking". Also, try to choose a password that could not be guessed easily. Often, a combination of both letters and numbers works best, as the laws of statistics dictate that more choices equal more failed attempts at cracking the code. Unless your child is exceptionally persistent or lucky, boredom will win out before they guess the correct code.
thnks
