Cycling Logo
A
Anonymous Posted on Jan 31, 2013
I have a RSP cycle computer but no instructions on how to programme it. an you help?
Have fitted it to my cycle but have no idea how to programme in details of anything. It came with a CD but this is far too complicated to understand. I fitted onto my bike following instructions on the CD but that's it.Can anyone help me?
1 Related Answer
locallad001
  • Posted on Oct 18, 2009
SOURCE: I need the fitting instructions for a 3 bike high
This should do it (if you havn't already found it).
http://www.halfords.com/wcsstore/libraries/document/metalclamp909903.pdf
Hotpoint bfz 700x
Perhaps you disturbed the interlock for the door lock. Recheck that. Another possible solution is to reset the "computer". Unplug or turn off circuit breaker for a minute or so, and then retry. I hope this helps, but I suspect you've already solved the problem.
tip
How to Configure Belkin routers for Centurylink, Embarq, Bell sympatico, Bell...
How to Configure Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs ?
Configuring Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs :
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Do not connect the modem to the router.
  • Open internet explorer / Firefox / chrome or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router i.e., 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
Wired Part Configuration:
We need to configure the wired part by following these steps.
Step 1: You need to LOGIN to the router for making any changes. (No login password, just leave it blank and click SUBMIT)
Step 2: Click on LAN settings (found on left side of RSP), change the IP address from 192.168.2.1 to 192.168.40.1 and save changes.
Step 3: Now Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using another Ethernet cable.
***Once you are done that, you need to re-login to RSP by typing the new IP address 192.168.40.1 in the address bar of web browser.
Step 4: Check for the internet status at the top right hand corner of RSP. If it is connected then the wired part is working perfect with the router (wired computers will go online). Need not follow the steps below, directly jump to wireless part configuration.
Step 5: If the Internet Status is not connected then, click on CONNECTION TYPE (found on left side of RSP), it has to be selected as DYNAMIC and click next. It will ask for HOST NAME, leave it blank or you can type anything there and click on APPLY CHANGES.
Step 6: Now check for the internet status at the top right hand corner of belkin RSP. If it says connected then everything for the wired part is configured perfectly. You can go ahead and configure for the wireless part.
If it is not connected then we need to do a network power cycle.
Steps to be followed for performing Network power cycle:
  • Unplug the power cable of both your modem and router.
  • Wait for 30 seconds.
  • Plug back the power cable of the modem and wait until all the lights are lit up in it.
  • Now plug back the power cable to the router and check for the lights in the router.
Modem & Internet lights will be lit and they will be solid (blue/green) in the router; it says that the Internet status is connected. Now you will be able to go online in the wired computers.
If still Modem & Internet lights are not solid in the router; it may be blinking in red/ amber it says that the Internet status is not connected. You will not be able to go online in the wired computers.
In this case you need to connect your computer directly to the modem and check whether you are able to go online. If you are not able to go online, then you need to contact your ISP and fix your issue with internet.
The above method is applicable only for Embarq, century link, Bell Sympatico, Bell Canada ISPs. Because these ISPs will have the IP address same as Belkin routers....
If nothing works then you need to contact your ISP and ask them to bridge the modem...Bridging the modem disables NAT in the modem and allows you to get a public IP in the modem.
click here to configure wireless part...
on May 09, 2010 • Computers & Internet
Have right parts but connection is wrong on stator for rsp on kenmore oasis mod, 110.27087603 rsp #10183157 and stator #10419333
W10183157 is the proper one for this machine. If you removed the stator did you maybe get the plug behind the staor when you installed it and can not see it now? Just asking
My new magnetic resistance bike is not working
The supplier or manufacturer can probably help you with this. Is there a support web site or toll-free number in the package.
1helpful
The quick wash (29minute and 44 minute) washes do not start. You can hear the motor(?) doing something, but the cycle doesn't start. Otjer cycles are fine.
Just had same problem with mine - fitted new motorized programme selector for £15.99 + p&p & now all programmes fully function.
1helpful
2answers
A 40 degree cotton wash takes around 3 hours to complete cycle, manual states 90 minutes, any ideas ?
It is possible the heater element is not working, you need a meter to test it with, and make sure you have selected the correct programm for what you are washing as some programmes can take up to 3 hours to complete.
Hope this helps.
1helpful
2answers
WD62 DOES NOT CYCLE THROUGH ITS PROGRAMME
hi, this model is notorious for programme faults and i would suggest you change the controller, hope this helps
Top Blackburn Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Blackburn Cycling Expert? Answer questions, earn points and help others
