I bought a Toshiba 22LV505 combo for a work out room at home. The volume is not loud enough when using equipment so I wanted to add additional speakers. I have a Sherwood RX-4105 receiver with two Bose speakers plus a Sony CD player and wanted to use that system for additional sound. I can not get my Toshiba to work with the Sherwood receiver. The Toshiba has a digital audio out but the receiver does not have a digital audio in. What can I do to make this work?
SOURCE: Is the Sony FD Trinitron WEGA KV-36FV27 36" TV a digital TV
This is an Analog TV - you will require converter box.
go here to order it:
https://www.dtv2009.gov/ApplyCoupon.aspx
jl
SOURCE: Sony KV25XS
Try going here:
http://esupport.sony.com/
Maybe you can find the manual for it. The manual should tell you how to change the TV to video. But there is probably a labeled button called video on the front/side/back of the TV that switches it. Unless that is a function that is now on the remote.
SOURCE: Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
SOURCE: How do you get DVD player SOUND to play through the TV speakers
plug the stereo headphone jack to your dvd headphone output then connect it to your tv audio/video in and press the tv/video switch in your tv remote control.
