Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Canon MP390 - "Data Error Press Set Key" Message
Need help to solve this error message. The printer was turned on with "Data Error Press Set Key" Message and alarm indicator flashing. After pressing all buttons, the 'set' key was later found to be on the numeric key "5". It seems that due to this error, the key functions were automatically misprogrammed. The Menu was set to key '+' instead of 'Menu' key. The Additional Functions was set to 'Directory" key. The Stop/Reset to numeric key '4'. The On/Off to key '#'....etc...etc. Moreover my pc couldn't recognise the printer any longer.
Any suggestions or clues to solve this problem is great appreciated. Thx.
  • 22 Answers
No free suggestions go to the authorised service centre or trying to get an live chat support from canon like I do from my hp printers
Posted on Mar 05, 2009
    New Friend:
In this case, insert a power cord while pressing the COPY button, and then press the START button. This will make key assignment performed normally. After that, please proceed with the shipping setting, referring to Shipping Setting Procedures.
Posted on Feb 26, 2013
  • luz peru
    luz peru Apr 10, 2014
    hello! can you please be more specific about how to proceed with the shipping setting procedures please? thank you!!! (i changed the battery on my canon mp370 and have the problem where the keys are wrongly assigned...)
    New Friend:
I also need help to reset so keys match correct function ... how is this done?
Posted on Dec 25, 2012
  • Pepe Feb 26, 2013
    Important Reminder when replacing MP370SPCNT When replacing SPCNT, there are some cases that SRAM is not initialized. In this condition, key assignment in the panel become inappropriate. In this case, insert a power cord while pressing the COPY button, and then press the START button. This will make key assignment performed normally. After that, please proceed with the shipping setting, referring to Shipping Setting Procedures.
  • Pepe Feb 26, 2013
    Maybe the moherboard battery needs to be replaced. Cr2450. Then perform shipping setting procedures. Battery lasts for approx. 5 years according service manual.
2 Suggested Answers
SOURCE:
SOURCE: Need help to solve this
i'm facing the same problem....pls help...tq
Posted on Jan 31, 2011
How to solve the error of canon iR2016 photocopy system error E003?
How to reset E000, E001, E003, and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" then Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Canon IC-MF6530/6550/6560/6580
No reset procedure is required, replacing the fuser is the only repair.
Canon D860 series
Press Additional Function key and the "#" key in that order. Go to Printer (number 7), select "Set", Select "Printer reset" and press "set".
Canon Printer Support Phone Number
Dec 06, 2017 | Canon Office Equipment & Supplies
I get "system error e000" message when i copy
1) Press the "Additional Functions" key.
2) Press the "#" key.
3) Press > to the "#7" printer function.
4) Press the "Set" key.
5) Press > to the "#4 Printer Reset".
6) Press "Set".
7) Press 8) Unplug printer, plug it back in, and turn it on.
Mar 14, 2011 | Canon Image Runner 1630 Copier Copier
We have a Canon imageClass D860. It came up with the error code E000. We have unplugged several times and left unplugged. When we plug back in, the error message is still there. Have any answers?...
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300/1310,1330,1370,1630,1670, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681/D880
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press Unplug printer and repower it.
Oct 11, 2010 | Canon ImageClass D880 Copier
Canon MP390-error message
You need to use brand new original genuine canon cartridges. with most inkjet printers the refills and the replica cheaper cartridges do not work
Jul 26, 2010 | Canon MultiPASS MP390 All-In-One InkJet...
I have a Canonmp390 printer & a message keeps
Error "Waste Ink Near Full"
Cause : The waste ink tank (which holds the ink used for print head cleaning) is nearly full.
Action : Contact the Canon Customer Care - Center.
Have a good day.
Dec 03, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
CARTRIDGE jammed
Always it show the error messages like this then go to the authorised service centre they will do the needful you guys cannot do it yourself were are not here to do any free service as such in many issues.
Feb 08, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Canon multipass mp390
sounds like it's not seated properly. That can happen when it's pressed in unevenly. Try to seat it straight on, with the printer on a shelf or table, at almost eye level.
Jan 06, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon D680 (Fax and Photocopier)
1. Press ?additional functions? key. 2. Press ?#? key. 3. Press the ?>? key until you get to number 7. 4. Press ?Set?. 5. Press ?>? key until you get to number 4 (printer reset). 6. Press ?Set?. 7. Select ?yes? if in a fuser error. If this does not work, you will probably need a new fuser unit. Ed
Jan 21, 2007 | Canon imageCLASS D680 Laser Printer
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
7,965 people viewed this question
Clive
Clive
old marine
old marine
