Question about Panasonic TX-42PT10 42" TV
TV WONT TURN ON, STAND BY LIGHT FLASHING 3 TIMES CONTINUOUSLY
I HAVE A PANASONIC TX-43P250H REAR PRO. TV. THAT WONT TURN ON. WHEN I TURN IT ON IT I HEAR IT ACTIVATE BUT THEN IT INSTANTLY TURNS OFF FLASHING THE STAND BY LIGHT THREE TIMES.
  • Anonymous Apr 26, 2009
    I have the same problem
Having problem with sony television the screen when its turn on no images found just found red color on the screen..
Posted on Feb 01, 2009
SOURCE:
Panasonic TX-L42E5B blinks 3 times which board is faulty
When an abnormality has occurred to the unit, the protection circuits operate and set the unit to stand by mode. At this
time the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
Fault maybe on the A board 3.3V SOS give me your email & i send you the full timing chart.
Apr 04, 2016 | Panasonic VIERA TX-L42E5B 42" LED TV...
TV flickers then turns off. Standby light continuously flashes red. All fuses, cables and batteries checked and no problem with sound.
The T con board controls the picture. It has a problem and needs to be replaced. You can get the board from:
TV Parts Universal TV Stands DLP Chips ShopJimmy
You can replace this board yourself if you're not afraid to take the back off the TV.
Oct 22, 2015 | Panasonic Viera TX-L50B6B 50" LED TV...
Panasonic TX-L42S10B has power but won't turn on
ok, this may be a silly question but when you turn it on and it starts flashing red, have you tried pressing the stand-by button on the remote. if a tv has been put on stand-by by the remote, and is then switched off by the set, when the set is turned back on it is still in stand-by mode and you need to press the stand-by button on the remote.
other than that I don't know.
Nov 08, 2013 | Panasonic TXL42S10B 42 in HDTVReady TV
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
Panasonic TX-P42X10B wont turn on - goes into standby
Hard to troubleshoot with just this info, the red light can be helpful if its 10 blinks repeating over and over replace the power supply first then the A board. Voltages check on the power supply would narrow down the culprit.
Post again if you measure the power supply voltages
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
May 03, 2012 | Televison & Video
Panasonic pt47wx52cf tv shut off and wont turn
Please count red light flashes and let me know. There would be long pause between flashes so count pause to pause. It is an error code of TV problem.
May 18, 2009 | Panasonic Televison & Video
Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Apr 22, 2009 | Televison & Video
i have a toshiba dlp doing that after research i found it to need a lamp replacement
Feb 01, 2009 | Toshiba TheaterWide 46HM84 46" Rear...
RED TINT
yOUR CRTS ARE SHOWING THE SIGHNS OF WEAR. ON THE FRONT OF THE SET BEHIND THE SPEAKER GRILL OR FRONT FACIAL. THERE ARE 6 CONTROLS 3 FOR SCREEN RED GREEN AND BLUE AND 3 FOR FOCUS RED GREEN AND BLUE. YOU CAN TRY TURNING THE RED SCREEN DRIVE CONTRIL COUNTER CLOCK WISE. JUST A VERY LITTLE BIT.
Jan 22, 2009 | Televison & Video
Rear Projection TV Cuts out Need to wait and then turn back on?
SOUNDS LIKE A FLYBACK PROBLEM AROUND $70.00 FOR PART
Dec 06, 2008 | Panasonic TX-42PT10 42" TV
Panasonic TX-42PT10 42" TV Logo
948 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
