Computers & Internet Logo
michelle smith Posted on Feb 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pop up box says no available space o GB?
No available space left on hard drive. Tryed defragmentation with no results.Warning box continues to pop-up while typing saying, there is not enough space on e-machine C; to type documents.
Bob Sloan
Level 3:
  • E-Machines Master 2,013 Answers
  • Posted on May 18, 2014
Bob Sloan
E-Machines Master
Level 3:
Answers
2013
Questions
Helped
356596
Points
8519
Click Start, then Computer. If it shows no (or very little) free space on C:, you are truly out of room and need to delete or move some files to another hard drive (external hard drives are good for this). To operate efficiently, a good rule of thumb is to have at least 20% of your hard drive free.
5 Related Answers
Anonymous
  • 101 Answers
  • Posted on Mar 22, 2008
SOURCE: I am unable to format
If it shows up in windows explorer as a drive, right click it and choose format and choose ntfs as the file format.
Do you know what format it is when you use linux? I dont think you can use a dos command to format an ntfs volume. Your message probably means it cant read FAT or FAT32 because it probably already is NTFS file format.
Anonymous
  • 22 Answers
  • Posted on Jul 29, 2008
SOURCE: I have the Maxtor One
Try disable the autorun features for your removable drive.
Autorun can be enabled or disabled for all Removable media types, such as a floppy or Zip disk. Windows systems are configured to enable CD Notification, other removable media are by default disabled.
The System Properties User interface only exposes the CD Enable or Disable selection. The setting reflected in this dialog makes an entry in the System Registry. It is in this same location that other media types are configured.
Notes:
  1. Modifiying the Registry is not for the inexperienced user. Anyone will tell you, be VERY careful.
  2. The modifications made in this case use Hex not Decimal numbers. If you are unfamiliar with the Registry or the characteristics of base numbering and Hex, studying these topics prior to making these modifications is advisable.
To Modify these Registry Settings, Use Regedit and navigate to the following Key:
HKEY_CURRENT_USER
Software
Microsoft
Windows
CurrentVersion
Policies
Explorer
"NoDriveTypeAutoRun"
The default value for the setting is 95 0 0 0. Change the first byte to 91. Restart the computer to make the new setting take effect. You may have to right-click on the floppy and choose AutoPlay from the menu to see the AutoPlay behavior.
Anonymous
  • 41 Answers
  • Posted on Nov 02, 2009
SOURCE: do you know about computer GB free disk space
Yes. you have 221 gb available disk storage left. 5 gb will hardly make a dent in that.
You can right click on the computer icon and then select properties to view a pie chart representation of available space if that makes it easier for you.
Testimonial: "thanks for your expertise"
Anonymous
  • Posted on Mar 11, 2010
SOURCE: DVD+/- Gateway issue DVD won't burn DVDs but plays them
I had the same problem. I finally got a knowledgeable tech at Gateway who knew that a patch had to be downloaded. I'm sorry but I don't have the link anymore but you might be able to find it in there white papers now that you know that it exists
Anonymous
  • 327 Answers
  • Posted on Jan 15, 2011
SOURCE: I want to get a new internal hard drive but I,m
Dear friend. in fact Serial ATA is SATA.
and i checked your Hard drive out.
your hard drive uses SATA technology to connect with the PC.
please vote
2answers
My laptop is Dell inspiron, It gives me warning of low disk spsce . At c there is operating system , in other place I remove unnecessary documents , still no solution
Hard disk maintenance should be carried once a month to make your computer run efficiently. This removes redundant and temporary files, recovers disk space and speed up hard disk access.
Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too.
Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment.
When this is completed repeat these steps for the D Drive if you have a D drive.
Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time.
tip
How to speed up your computer's performance?
<p><b>Information:</b><br /> <p>There are some few guidelines that you can follow to maintain your computer and keep it running smoothly. <br /> <p><b>Free Up Disk Space</b><br /> <p>By freeing disk space, you can improve the performance of your computer. The Disk Cleanup tool helps you free up space on your hard disk. The utility identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.<br /> <p><b>Use Disk Cleanup to:</b><br /> <p>&bull; Remove temporary Internet files.<br />&bull; Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).<br />&bull; Empty the Recycle Bin.<br />&bull; Remove Windows temporary files.<br />&bull; Remove optional Windows components that you don't use.<br />&bull; Remove installed programs that you no longer use.<br /> <p> <br /> <p> <br /> <p><b>Tip:</b> Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.<br /> <p> <br /> <p><b>To use Disk Cleanup</b><br /> <p>1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Cleanup. If several drives are available, you might be prompted to specify which drive you want to clean.<br /> <p> <br /> <p> <br /> <p>Disk Cleanup calculates the amount of space you will be able to free.<br /> <p>2. In the Disk Cleanup for dialog box, scroll through the content of the Files to delete list.<br /> <p> <br /> <p> <br /> <p>Choose the files that you want to delete.<br /> <p>3. Clear the check boxes for files that you don't want to delete, and then click OK.<br /> <p>4. When prompted to confirm that you want to delete the specified files, click Yes. <br /> <p>After a few minutes, the process completes and the Disk Cleanup dialog box closes, leaving your computer cleaner and performing better.<br /> <p> <br /> <p> <br /> <p><b>Speed Up Access to Data</b><br /> <p>Disk fragmentation slows the overall performance of your system. When files are fragmented, the computer must search the hard disk when the file is opened to piece it back together. The response time can be significantly longer.<br /> <p>Disk Defragmenter is a Windows utility that consolidates fragmented files and folders on your computer's hard disk so that each occupies a single space on the disk. With your files stored neatly end-to-end, without fragmentation, reading and writing to the disk speeds up.<br /> <p><b>Run Disk Defragmenter</b><br /> <p>In addition to running Disk Defragmenter at regular intervals, optimally monthly, certain events warrant running the utility outside of the monthly rule of thumb.<br /> <p>You should run Disk Defragmenter under the following circumstances:<br /> <p>&bull; You add a large number of files. <br />&bull; Your free disk space nears 15 percent. <br />&bull; You install new programs or a new version of Windows.<br /><br /> <p> <br /> <p><b>To use Disk Defragmenter:</b><br /> <p>1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Defragmenter.<br /> <p> <br /> <p>Click Analyze to start the Disk Defragmenter.<br /> <p>2. In the Disk Defragmenter dialog box, click the drives that you want to defragment, and then click the Analyze button.<br /> <p>After the disk is analyzed, a dialog box appears, letting you know whether you should defragment the analyzed drives.<br /> <p><b>Tip:</b> You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.<br /> <p>3. To defragment the selected drive or drives, click the Defragment button.<br /> <p>After the defragmentation is complete, Disk Defragmenter displays the results.<br /> <p>4. To display detailed information about the defragmented disk or partition, click View Report.<br /> <p>5. To close the View Report dialog box, click Close.<br /> <p>6. To close the Disk Defragmenter utility, click the Close button on the title bar of the window.<br /> <p><b>Detect and Repair Disk Errors</b><br /> <p>In addition to running Disk Cleanup and Disk Defragmenter to optimize the performance of your computer, you can check the integrity of the files stored on your hard disk by running the Error Checking utility.<br /> <p>As you use your hard drive, it can develop bad sectors. Bad sectors slow down hard disk performance and sometimes make data writing (such as file saving) difficult, or even impossible. The Error Checking utility scans the hard drive for bad sectors, and scans for file system errors to see whether certain files or folders are misplaced.<br /> <p>If you use your computer daily, you should try to run this utility weekly to help prevent data loss.<br /> <p><b>To run the Error Checking utility:</b><br /> <p><b>Important:</b> Be sure to close all files before running the Error-Checking utility.<br /> <p>1. Click Start, and then click My Computer.<br />2. In the My Computer window, right-click the hard disk you want to search for bad sectors, and then click Properties.<br />3. In the Properties dialog box, click the Tools tab.<br />4. Click the Check Now button.<br />5. In the Check Disk dialog box, select the Scan for and attempt recovery of bad sectors check box, and then click Start.<br /> <p> <br /> <p>In most circumstances, select Scan for and attempt recovery of bad sectors.<br /> <p>6. If bad sectors are found, choose to fix them.<br /> <p><b>Tip:</b> Only select the Automatically fix file system errors check box if you think that your disk contains bad sectors.<br /> <p> <br /> <p>Hope this will help...<br />
on Jan 17, 2011 • Computers & Internet
tip
How to Perform a Defragmentation of your Hard drive, to increase performance!!!
When you install a program on to your computer's hard drive it just simply does so in the quickest way possible. Meaning it will install a program in the first available space that it can find, usually many different places, therefore resulting in what is known as fragments.
These fragments are often far appart causing your computer to become slugish as it has to find the fragments that it needs, to perform the task at hand.
You can therefore make your computer more responsive by arranging these fragments into contiguous pieces of information. In other words all information relating to a program is together in one piece making it quicker to read by your computer system.
This is done with the help of a program called Disk Defragmenter.
Follow these steps;
1.)Double Click My Computer
2.)Right Click the hard drive that is your system drive, usually drive C:
3.)Select Properties
4.)Select the Tools Tab on the top of the box.
5.)Under the Defragmentation heading click Defragment Now...
6.)Disk Defragmenter Now appears.
7.)Select the system disk again usually drive C: (The one with Windows installed on it.)
8.)Now click the Defragment button.
It will take a number of hours to complete, so only perform this when you have the time for it to finish.
The bigger your hard drive the longer it will take.
The benifit of this session is that it makes the computer operate more effieciently and will become more responsive.
The Disk Defragmenter is performed at about once a month, to maintain a good system.
Enjoy the extra performance!
damnor01
on Jan 16, 2011 • Computers & Internet
Fix syncing issues?
Clean up System & Sync Issues Folder Microsoft's Disk Defragmenter, which is built into the operating system, makes computers run faster. It does this by reconfiguring where data is stored on the drive. This will speed up the hard drive and fix syncing issues.
Click "Start." Type "Disk Defragmenter" in the search bar. Left-click the result labeled "Disk Defragmenter." Click on the "C:" hard drive. Click "Defragment disk." The process will take several minutes to complete.
Hi, I have WD 1TB Elements SE. When I checked the usage space on the partition after I plug in the drive, it shows a total capacity as 1,000,200,990,720 bytes (931 GB) and it shows 921,753,505,792 bytes...
If you have a 32bit system, it is expected to have miscalculations, a 32 bits can only go up to 4Gb for calculations (that is, 2^32 = 4'294'967'296 bytes) a 64bit system can make calculations to 2^64 bytes this is also why you couldn't copy a file larger than 4Gb in a 32bit operating system...
So, if you are running a 32bit OS, you should expect a discrepancy for the total space of the Hard Drive and the amount it shows (that's the 93Gb you are missing as total capacity).
Another reason why it can show you incorrect calculations are damaged sectors on the hard drive it-self. These will present themselves either as occupied memory or missing memory.
So, you should expect some miss calculations and you can expect some damaged sectors on the hard disk (a external drive spins on and off too often, eventually damaging sectors... its a problem of physical drives).
In the end, your disk might be fragmented, so run a disk analysis and a defragmentation on the disk so it can recalculate.
A note: A disk is like a shelve, you put things where there is space, if you remove things, that space will be open, and if you want to put something there it has to be the exact size or small enough to fit there. This effect, when things are small enough leaves blank spaces unusable, consuming space on the hard drive and making the access of files slower, this is fragmentation. In order to expand your disk life expectancy you should run defragmentations...
To run a defragmentation, go to START, write "Disk Defragmenter", choose your disk and run and analysis and defragmentation.
tip
How to Maximize and Fix the Size of Your Windows Swapfile
<b> <br /></b> Whenever Windows needs more memory than the RAM that you have installed, it uses some of your hard drive space as memory. This memory is referred to as virtual memory, and the space it uses on the hard drive is called the Swapfile.<br /> At the time Microsoft incorporated the Swapfile concept into Windows, hard drive space was at a premium. We were referring to hard drive sizes in megabytes, not in terrabybes as we do today. <br /> According, Microsoft allowed windows to dynamially change the size of the Swapfile (between pre-determined minimum and maximum values) proportional to real-time system memory requirements. This method insured that the "premium" hard drive space would be not be used by the system when there were minimal or no virtual memory requirements.<br /> However, there is some overhead involved with this method of determining Swapfile size as Windows has to continuously allocate and de-allocate hard drive space for use by the Swapfile. Considering the size of today's hard drives, we frequently find 30 or more Gigabytes of hard drive space available (especially on today's home computers). And Swapfile requirements are usually between 1 Mb. And 1 Gb. (1 Gb. = 1,000 Mb.). <br /> Considering the above, if you have an extra 10 or 20 Gb. of available hard drive space, why not set the minimum and maximum values of your Swapfile size to be equal, and relieve Windows of the task of managing your Swapfile size?<br /> To do this, perform the following procedure in Windows XP:<br /> NOTE: This procedure will be somewhat different for other operating systems.<br /> Click on START, and then CONTROL PANEL.<br /> Set contol panel to the "classic mode"<br /> Double click on SYSTEM. And in the Systems Properties box, click on ADVANCED<br /> In the Performance Box click on SETTINGS and then click on ADVANCED<br /> In the virtual memory box click on CHANGE<br /> NOTE: If you have more that 1 drive (volume), all will be listed. Only change the swapfile setting for the volume that presently contains the swapfile.<br /> In the virtual memory dialog box, click on the SWAPFILE DRIVE and click on CUSTOM SIZE.<br /> The initial and maximum sizes of the Swapfile will now be highlighted.<br /> The maximum size should be less than 20% of the available space (listed above the swapfile sizes). If it is not, you may not want to apply this procedure as your hard drive free space is somewhat limited.<br /> To continue, click on the INITIAL SIZE box and change the size to be the same as the size contained in the MAXIMUM SIZE box. Then click on SET and then OK.<br /> Close all dialog boxes and re-boot your computer.<br /> ~~~~~~~~~~~~~~
on Dec 13, 2010 • Computers & Internet
tip
Information: There are some few guidelines that you can follow to maintain your computer and keep it running smoothly.
Free Up Disk Space
• Remove temporary Internet files.
• Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
• Empty the Recycle Bin.
• Remove Windows temporary files.
• Remove optional Windows components that you don't use.
• Remove installed programs that you no longer use.
Tip: Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.
To use Disk Cleanup
• You add a large number of files.
• Your free disk space nears 15 percent.
• You install new programs or a new version of Windows.
Tip: You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.
Important: Be sure to close all files before running the Error-Checking utility.
Tip: Only select the Automatically fix file system errors check box if you think that your disk contains bad sectors.
on Jul 05, 2010 • Computers & Internet
315 GB space available but can't add more data
Are the files that are on the drive all on the root C:\(or whatever letter it's using) or are they organized into folders such as Pictures/music/documents?
Second, what file format is the drive FAT32/NTFS(to find out right click on the drive in My Computer, left-click properties and in the window that pops up near the top you will see file system: _____
Answer back with that info and I will see what I can do to help you.
Chris
Vista recovery/hard drive
hi your hard drive is a 250gig when your reinstalling vista it will think that your pc needs to split the hard drives for recovery this is why its done that and because of that it will use a small part of the hard drive for its own mem use so you will lose the total size of the hard drive im running 1000gig and only getting 800 gig for my self this you cannot do anything about .
the only thing you can do is reinstall your vista program and when on the screen for formatting the hard drive it will say do you want to format the partitions in the box there will be a delet this partition you must delet all the partitions so there is only one left then you must reinstall vista on that one only this will get rid of all the other ones so you sould be left with just 1 hard drive when you start up vista this should put you back on to close to 235gig
hope this works for you
all the best thanks
1helpful
Drive will not complete the back up
This error represent no available space to store for backup file.
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
