There is 6 oz of a food safe lubricant in the motor housing that is held in by a gasket around the front of the gear housing in the top of the mixer, the gasket is leaking the separated liquid of the grease. The grease because it is a vegetable based product separates over periods of non use and the gasket gets soaked and releases the liquid into parts of your mixer and it drips it's way out when you use it. the best thing to do is install a new gasket and remove the old grease then repack and add a new gasket. There wasn't that easy?? problem is that most people don't know where to buy the KA approved grease and gasket (ebay about 17.00) and most people don't know how to take their mixer apart to do this, (youtube has about four really good step by step videos on how to do it) BUT!!!! there is a trick that often works, seriously!!! get a towel and spread it on an open work space, grab your significant other or any one that will tolerate you when you get this way you will need their hand. Now turn the mixer upside down (no I'm not being sarcastic) turn it upside down, now have your partner hold it while you reach down and plug it in and turn it to speed Two, and hold the mixer like that for two minutes, (that's why it's better to have a really good friend help you they won't tell you how nuts you are doing this, but!! continue. After two minutes turn the mixer off and turn it right side up and turn it on again for two minutes, then do it all over again upside down then right side up, do this at least three times. the drip is now fixed. You think I'm nutz right??? Wrong!!! What you have done is re-mix the gear grease, the liquids are now re-mixed with the solids or gear grease base material. It should last about a year or so. My suggestion is to do this once or twice a year if you are not going to use the mixer for long periods of time. The separation usually happens when the mixer goes for long periods of time without use. the grease is designed to work for five or ten years without being replaced. however the gasket is made of fiber and the weight of the motor head pressing down on it for a few years of say 17 pounds causes it to compress and allow the liquids to leak out. So to fix that you take of the drip ring off (round silver thing that attaches to the planetary ) then drive out the little silver pin in the planetary shaft and pry off the planetary. you will then see five flat head screws that hold the motor head to the lower gear case, thightem them up and re-assemble the mixer then remix the grease, you have fixed your drip problem without spending a dime and it will stay fixed for years as long as you have no other issues arise during it's life. Hope that helps you.
