Fn+F8. I see on the external monitor somethig happend but no images.
SOURCE: My notebook Asus W7J BLANK when is turn on
Screen not working
are you able to hear the windows log in?
if you do but no image, most likelly your
video card is ruined. overheated or dropped maybe?
don't worry is bad but not that bad, there is a way to fix that by a professional.
take it to a computer repair shop and have them check the video card ask if they have a rework station or someone who may. they have to unsolder about 50 pins at the same time get a new card and solder it again.
sometimes they apply heat to it and it will work again but for just a few days maybe weeks but it goes bad again. so replacement is the best option.
I used to charge about 200 bucks but you may be able to ask for a rebate.
do not take it to a major computer store they would tell you there is no repair so you can go in and get a new computer
Testimonial: "exactly what i think"
SOURCE: white screen on lcd nothing visible but output ok
i think you should try Fn-F5 not F6 hold the button down a while
SOURCE: when using external monitor i
need to configure the Graphics Properties, Right click over the desktop
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
when you select the no 2 tab this should be the extended desktop always click apply after making any changes
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
hope it helps
Shine
a flashlight on the dark screen to see if you barely see the icons on the
desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be
any kind of monitor even the old big fat crt monitors as long as it has a vga
cable to connect to your computer's vga port. If the video shows on the
external monitor that proves your video card is ok, ,but your lcd screen is
bad. The video will show on most systems when you reboot without you having to
do anything. Some systems will require you to hit the FN (Function key) + F1
thru F12. Hold down the FN key then hit the correct key for displaying on
the monitor (F1 thru F12). The correct key will normally have CRT/LCD on
it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,
then your screen is bad. If you see no icons by shinning the flash light
and nothing shows on the external monitor, then most likely your video card is
bad.
