Freezer freezing up and the drain is not stopped up what could be the problem
SOURCE: Freezer drain line and upper drain pan freezes up regularly.
sounds like your fill tube is leaking
you should be able to pull it out from the back of the machine
to inspect it
if the fill tab on the tube is facing in any other direction than down it should be straight down
SOURCE: Ice freezes in freezer bottom and drain stops up
Also check for bad door gasket or door left open for long period of time. There is a solution, you can install a low heat heater into the drain hole and connected it to defrost heater wires. Good luck.
