My phone is lg gu220. whenever i open default browser it opens a blank page and got hang.. even i cant exit from broser.. i have to remove battery and restart it.. any solution please
INSTALL THIS BROWSER OPERA MINI DOWNLOAD LINK
http://www.opera.com/mobile/download/lg/
SOURCE: phone dead after opening java executor
I had the same problem with a k800i, i emailed sony ericsson and they told me what to try and it worked however you do lose everything you had stored on your phone. I believe this will work with most if not all sony ericsson phones. You need to update your phone, here's what to do;
1.Go to www.sonyericsson.com/support
2.Select UK
3.Select your model of handset
4.Click on Sony Ericsson Update Service
5.Click the link, and then click Run or Save.
6.Let the Sony Ericsson Update Service install.
Once
you have installed the Sony Ericsson Update Service you will need to
launch it. Once it opens simply follow the instructions that you will
see on screen. The update should then begin.
SOURCE: when i open my images on my lg kp500 (cookie) my phone restarts
This happened to me, it seems to be caused by disconnecting the USB lead from the phone before you press 'disconnect' on the handset.
I guessed there must therefore be a corrupt file in my image folder so i saved copies of all the pics on my phone on my PC. Then deleted all my images. When i put them back on the problem was gone, my phone works fine.
Give it a go and see if it works for you.
SOURCE: How download a themes for
Themes you can download from below websites
www.zedge.com
www.ownskin.com: In this website you can create your own themes.
For software you can download from below website
www.mobile9.com
www.themobilefile.com
Thank You
SOURCE: MY NOKIA N72 HANGED WHEN
hi,
your phone software crashes or corrupted. we can do nothing about it unless we have a special gadget used to fix mobile phones and buying it cost so much for that purpose only.
To save time and money, I recommend to have it reformat at your nearest service center or dealer if it still has the warranty or to trusted mobile phone repair shop.
Hope I helped you in some other ways.
Don't forget to rate me. Thanks...
Best regards,
John
SOURCE: i cant open my browser.if i open it my phone was
Its a virus.Run a virus scan and remove the virus with the help of a computer.
try a firmware update, this info should be available from LG.
