Question about Minolta bizhub 180 Black and White Copier
MAINTANANCE M2 MINOLTA BIZHUB 163 - Minolta bizhub 180 Black and White Copier
  • Minolta Master
  • 6,850 Answers
Need to have the drum and developer and cleaning blade replaced, then have that M2 counter reset. Resetting the counter with out replacing the drum developer and cleaning blade will cause codes and image problems. Machine uses the counters to determine voltages for certain assy. If you clear the counter and not replace the parts the machine adjust voltages for the drum and developer assuming it new when in reality it is old.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Feb 07, 2015
3 Suggested Answers
SOURCE:
  • 26 Answers
SOURCE: Driver utility of Konika Minolta Bizhub 162
Use the bizhub 180 same family
driver
Posted on Feb 21, 2009
  • 15 Answers
SOURCE: minolta Ep4000 show CodeM2
Set the copier into Tech. Rep. mode by pressing the following keys in this order : utilty meter count stop 0 stop 1 then from the menu select counter then select Maintenance select the conter then enter anew value from the 10-Key pad
Posted on Apr 11, 2009
How to remove error code M2
question too vague.
make? model?
example:
Re: Konika Minolta BizHub 163 - Error Code? M2
• To display the count of the supplies life counter.
When the counter reaches "0", life 1 will be detected and maintenance call M2 will appear.
The initial value is 40,000, and the countdown system is used.
Use Setting/Procedure
• To clear the count, use [CLEAR DATA] of the Service Mode.
Jun 06, 2015 | Office Equipment & Supplies
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
Sep 21, 2014 | Konica Minolta bizhub Office Equipment &...
Bizhub 164 maintanance call m2 solutions iam neede
press the Utility button,
then Stop 0 0 Stop 0 1
then scroll to Clear Data, and then Supplies Data and clear.
You must be aware that clearing this counter clears the drum, developer and other counters.
Which are very important for copy quality, and not replacing them may cause more harm than good.
Jul 04, 2014 | Minolta bizhub 180 Black and White Copier
How to solve M2 in bizhub 164
Konika Minolta BizHub 163 - Error Code M2
Press the Utility button,
then Stop 0 0
then press again Stop 0 1
Feb 23, 2014 | Minolta bizhub 200 All-In-One Printer
Will not run
MAINTANANCE CALL (M2)
Jan 24, 2014 | Minolta Bizhub Di1811p Copier
Bizhub 163 eror code M2
no such counter m1?
Jan 23, 2014 | Konica Minolta bizhub C250 All-In-One...
Konika minolta bizhub 164 how to enter into service mode
KONOCA MINOLTA 164
ERROR FOR MAINTANANCE CALL(M2) ,PLEASE SOLVTHE PROBLEM
Jan 05, 2012 | Minolta Office Equipment & Supplies
How can i reset m2 bizhub 211
I Have a Konika Minolta bizhub 211. I had been trying this solution for repairing m2 call. but the code is appear till now. anyone help me. please give me solution step by step.
Thanks
Mar 05, 2011 | Sharp AR-5320 Black and White Copier
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Dec 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
Desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
May 18, 2010 | Konica Minolta bizhub 161f All-In-One...
Minolta bizhub 180 Black and White Copier Logo
147 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
