Hello, It may be the battery draining all the current and not allowing the motherboard to receive enough power to boot. Can you please remove completely the battery and try to boot again? Please let me know more details and I will guide you to the next step.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Try reinserting the battery. of nothing happens, then most likely you need to replace your battery as the circuit inside the battery might be fried already.
umm well i had the same problem and it was a ribbon cable that came off so opening it up remember there are 4 screws under the battrey in the compartment and there is a strip hiding 2 screws
hopre it helps
pleaqse post me bak if you can not find the ribbon cable ok ill help
