Bosch 33614-2g 14.4v Brute Tough 1/2" Cordless Drill Logo
Posted on Jan 31, 2009
Bosch 18volt brute force cordless drill how do i remove chuck
Bosch 18 volt brute force cordless drill i have removed screw in centre of chuck but unable to remove chuck is it possible
  • 1 more comment
  • Anonymous Mar 16, 2014
    how do i remove the drill chuck?
  • Anonymous Mar 18, 2014
    bosch drill chuck cannot open stuck ,, how to solve ?
  • Anonymous Mar 23, 2014
    how do you remove the armature from the intermediate flange
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2514
Points
15
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
  • waterwidget Mar 11, 2014
    Tried the suggestion but the gearbox must be jammed, how do I remove the gearbox?
My new bosch cordless drill chuck doesn,t have a screw in it how do i remove the chuck ?
Dear Fred,
Please go to Replacement Parts in the link provided below. Too replace and remove your drill chuck on a cordless drill.
How to Remove Drill Chuck
Fare Well
Need to remove chuck on new BOSCH DDS181-02 18v cordless drill. No screw evident @ bottom of chuck-only small 1/16" hole. How do I remove chuck?
There is supposed to be a Phillips head LH thread screw in the chuck. I have seen the screw head worn down so you can no longer get a screwdriver to work.
We usually cut the chuck off with a metal chop saw just at the screw - thread what remains of the chuck off, which usually leaves 1/4" of the screw sticking out of the spindle - remove with vise grips.
Its not an easy prospect when that happens.
1helpful
Bosch 12V cordless drill PSR 1 ?ES-2 One of the three jaws unscrewed a little and protruded beyond the other jaws by approximately 4 mm but has now completly unscrewed and fallen out. I can not unscrew...
It is left hand thread and yes sometimes you have to use a little force to loosen it. I don't know if you will be able to reinstall the jaw from the chuck, I havea detailed instructions on chuck removal in my tip section.
1helpful
How to use hand drills?
Use of both is the same:
- loosen "chuck" (part where bit is installed).
- insert bit (hand tighen chuck so that bit is secured)
- tighten chuck securely with chuck tool, or by holding rotating chuck with hand and pulling trigger (GENTLY or you will shave off skin!)
- put drill in forward or reverse mode and pull trigger to inser or remove screw / drill hole.
ensure that battery is charged on cordless drilll.
squeeze connectors to remove and place in charger when battery is too low to operate drill.
How do you remove the chuck on a 18volt makita drill driver
there is a flat head screw in the center of the keyless drill chuck counter clocwise to remove.
How to change a chuck on makita 8444 drill
Hi there, the chuck will screw onto the spindle of the drill but there is also a screw to undo. Open the chuch out fully then look down the centre of the chuck and you will find a philips head. The thread on the screw is opposite to the normail way so instead of undoing to the left, undo to the right.there should be threadlock on the screw so may be abit tough for the first turn. Once removed a strong pair of grips and a good tug should then remove the old chuck, some are more orqard than others to remove so just keep trying.
How to change the chuck on a draper red line 18v cordless drill
The screw you are trying to remove is left hand thread. You must turn is clockwise to remove it.
Hope this helps
1helpful
I need to remove the chuck on my Bosch 33618 Brute cordless drill. How do I do it?
You must remove the inner chuck retaining bolt first, it is a torx screw and is left hand thread. once you have this screw out, get yourself a 1/2" allen key (the L kind). Chuck the short end in the chuck to grip it, use a mallet to hit on the long end (this will unthread the chuck). The spindle thread is regular Right hand thread. It may take a few good hits to knock it loose but it will come off.
Top Bosch Drills Experts
Paul Carew
john h
Are you a Bosch Drill Expert? Answer questions, earn points and help others
