SOURCE: Sony KF-60WE610
Some of the ICs on the power supply block are damaged. This can possibly due to high voltage or defective IC. What you can do now is to get a new PS block. If you can get me the part number i can help you find it..
SOURCE: Sony Grand Wega 60WF655 TV blue tint/spots
sounds like your optical block lenses has melted due to heat.
( common problem) here is the light engine/optical block number
A-1084-658-A
SOURCE: I have a Sony Grand Wega KDF-55E2000, I just
I have the same issue, and it appears to be the optical block. Sony has extended the warranty to replace these through June 2010.
http://esupport.sony.com/perl/news-item.pl?news_id=293&mdl=KDF55E2000
SOURCE: changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
SOURCE: I need to replace my 42 in Sony WEGA HDTV
Lamp code XL-2400 is Sony part number F93087500 and it is available on http://www.partstore.com/. You may also decide to purchase the less expensive Philips Lighting lamp part number F93087500RL. Either will work for your television set.
