What ports do I use on the Hisense and cable
SOURCE: trying to hook up laptop with haier tv using vga
Dod you use HOTKEYS on the laptop to tell it to send the signal the VGA outlet of the laptop? The hotkeys function can be set to turn off the laptop screen and only have external monitor to be the only display or it can be set to have both of them on.
SOURCE: Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
SOURCE: I need to hook up to digital cable
Thank you for your time.
I turned on the router supplied by Verizon, which I did not do yesterday, I'm embarrassed to say....
I called Sanyo and received step by step how to set up.
It was the same procedure I used yesterday with the exception of making sure the router was on,
I apologize for any inconvenience.
Reva L,
SOURCE: LHD3204US 32 in. HDTV LCD Television: I can't get any power to my 32" Hisense TV model n...
Have your checked or replaced the fuse in the plug?
