Can the AC/DC adapter be replaced with another new one, and if so, how much does it cost, and where can I get one?
SOURCE: AC Adapter is no good
you may be able to get a generic power adapter from a place like radio shack, take it with you and they will match and find the correct voltage, current rating and plug. I've done this many times for hard to find AC packs.
but if you want an original you can get it here
hope this helps
thanks for your rating
SOURCE: to purchase a power supply adapter for the printer
ebay sells replacement s take look on ther once ok thx nick
SOURCE: need a ac adapter for x1150
If you need a AC adapter for this printer you can just go to a local electronic or computer shop near you and just tell them that you're looking for a AC adapter and give the model number of the printer...
SOURCE: It won't power on..is the ac adapter bad, or something else?
Sorry about that ... my pc just went beserk ... possibly but a sure way to know it to measure its output. Take to any repair shop they would check it for free for you.
SOURCE: AC Adapter failure z645 printer
If you can not get that power adapter locally, search for it on the web at auction sites, and computer supply web sites.
Take an ink pen and push the tip inside the jack and see if
the little pin wiggles, if so the jack is bad. You'll have to take the laptop
apart to fix it. Most times it is soldered onto the motherboard, so you
will have to desolder the old and solder a new one.
If the DC Power Jack is bad, then eventually the battery is going to die and you won't be able to boot your laptop. If the dc power jack is bad, the ac adapter power cord can't charge the battery.
