Question about Konica Minolta bizhub C250 All-In-One Laser Printer
BizHub C252 - error Code C-2555 (Malfunction Detected)
My daughter was playing with buttons while something was printing. A page became stuck (which I have since pulled out) and now it it gives me the "Malfunction Detected - Contact your service representative C-2555). In trying to save $$ is there anything I can do myself to detect and correct the problem. I have tried powering off and turning the maching off as well. Your help is greatly appreciated.
  • Anonymous Feb 01, 2009
    SAME PROBLEM AND I AM IN KY WE HAVE BEEN WITHOUT POWER FOR 5 DAYS POWER IS NOW ON AND MY MACHINE IS DISPLAYING THE SAME MESSAGE IHAVE BIZHUB C250
  • Diego Aug 08, 2013
    If you dont want to spend more money on a Image unit, once that happens and nothing else works.... do NOT buy a new IMAGE UNIT... Pull it out, Open the little part where the ''toner goes'' you will see it, its just like a toner cartridge but on the bigger scale. Get some of the ''Toner from the cartridge and pour into the image unit.... '' Trust me it does WORK !!!!
    Sniper:
  • 62 Answers
C-2555 relates to a low toner density in the yellow imaging unit. I'm sure your daughter pressing buttons did not cause it.
I suggest you release the yellow imaging unit (the bottow row of units)
Just realease and pull it out a little way. Then switch the machine on with the door open. It won't start, but will ask you to shut the front door. Reseat the yellow imaging unit and shut the door. The machine should go in to a stabilization mode and then work.
However, if it comes back, I suspect a new yellow imaging unit will be required.
Posted on Feb 07, 2009
  • 4 more comments
  • bigmurr2000
    bigmurr2000 Aug 07, 2012
    Great help! It worked. Thank you very much!!!!
  • heri_jemba
    heri_jemba Nov 23, 2012
    same... its worked... thanks
  • alexbastidas
    alexbastidas Mar 25, 2013
    tengo el codigo c-2555 que hago
  • marcos Apr 23, 2013
    Tengo el mismo tipo de problema, codigo c-2553 no se que hacer alguna ayuda que me puedan proporcionar anticipadamente gracias...
  • Dave Fobare
    Dave Fobare Mar 09, 2016
    This nailed it for me. Thanks much!
  • Michael Waweru
    Michael Waweru Nov 05, 2017
    It worked. Michael from Kenya - Africa
    New Friend:
Posted on Aug 08, 2013
    New Friend:
Taminol, Thank you very much. Worked Great.
Posted on Mar 19, 2015
    New Friend:
I followed Taminol's suggestion and it worked!!! Thanks a lot and a SAVED a ton of money by NOT calling a technician.
Posted on Oct 31, 2014
SOURCE:
Error c252
no such code for bizhub c252
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 01, 2014 | Konica Minolta bizhub C250 All-In-One...
Canon pixma mx516
"I did get pages stuck and had to pull them" That probably is what caused the misalignment. Maybe some part got bent. PIXMAs can be rather delicate.
Jul 14, 2017 | Canon PIXMA Office Equipment & Supplies
Error code c252
Main Motor failure to turn, PROBABLE CAUSES:
1. The main motor (M1) has failed.
Replace M1 (p/n 4038 M101 00). If the problem persists replace PWB-M (p/n 4038 0101 05 for bizhub C250 and p/n 4038 H001 01 for bizhub C252
Jan 27, 2014 | Konica Minolta bizhub C250 All-In-One...
Can done one help me to solve tej?a error on The c252 bizhub code c4551
Printer will not print
Jul 27, 2013 | Office Equipment & Supplies
I can't print on multiple size pages in the same job.
if there is a setting , it will be in the printer set up
however if there is not , you have to alter the page size before pressing the print button
Dec 12, 2017 | HP Laserjet P3015X Printer
Error c-0200
konica minolta bizhub malfunction detected error code c-0200
Sep 01, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Black lines running down on the Konica Minolta bizhub c252 copier?
Does this happen when you print? does this happen when you make copies on the big glass. Does this happen when using the document feeder?
Jan 23, 2012 | Minolta Office Equipment & Supplies
Printing to bizhub c252 from one computer a problem
s it a shared printer? if it is, install the driver as a local printer
May 27, 2010 | Konica Minolta bizhub C250 All-In-One...
Malfunction(Code 3451) of Bizhub C252
This is a fuser heat error. The fuser unit is located in the area where the paper exits the machine. It heats up and "fuses" the toner onto the paper. The error code means that it did not heat up properly. This means you will most likely need a service person to come out and diagnose the problem.
You can try to reset the error but I doubt it will help.
Turn off the MAIN power switch (not the one on the control panel)
Now hold down the utility key while turning on the main switch and continue holding the utility key for at least 10 seconds. You should see a screen come up with nothing but "trouble reset"
Touch trouble reset and you should see a small "ok" come on. Then turn off then on the main switch again.
Good Luck and Thank You for using Fixya.
Apr 01, 2010 | Office Equipment & Supplies
My daughter stuck money into the Wii console, now it will not play game discs.
my son had stuck two quarters in our wii and my husband opened it up and took them out. it started playing right after that.
Nov 15, 2009 | Nintendo Wii Console
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
15,600 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
