Hi there! ihave a problem wit our Eiki LC-SB20 Projector. it won't power up, when i press the power on button on remote control and power button on projector the power led lit (green) and suddenly blinking (red) then the unit is turning off. I really appriciate your help.... thanks and GOD BLESS!
sir Benimur thanks for the prompt solution and also for the link on manual...
i followed the steps on manual but still the unit is always "cooled down" it means there is something wrong with the unit.. can i ask favor to every one here if you have an idea please help me.
my place is far from the city i need to travel 3.5 hrs before i bring it to the service personel. thanks in advance to every one..sir Benimur thanks for the prompt solution and also for the link on manual...
AnonymousMay 05, 2008
hello,,,, i have lc-sb20 projector ,when i plug in power cord after few second blinking the red light stil red & not comming the green, please help mehello,,,, i have lc-sb20 projector ,when i plug in power cord after few second blinking the red light stil red & not comming the green, please help me
You can't post conmments that contain an email address.
The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service.
A copy of your manual is available at
http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf
Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
1.leaking polarised glass parts in the blue channel.
2. worst case a leaking lcd panel, impossible and very expensive to replace, you will need a complete optical block
you have to press the red button twice !! on screen you should see POWER OFF ? after first press, press once again to confirm.
Check if key and remote lock are both off.
Hello again gabzky,
My apologies for getting back to you a bit late. I understand that you followed the manual but was not able to resolve your problem.
There is something else you can try, hard reset the unit. At the back of your LC-SB20 Projector between DVI-I and Service port, above and to the left of the computer/component in is a small reset button. You may need to use a ballpen to depress the button.
You have to press this with the power on.
Cheers and keeping my fingers crossed for you.
