When the pc boots up look in the lower leeft and right corners to see which key will allow you to got to boot device order and then after you find it out press it on boot several times until it shows them all then use arrows and enter to select your device. Keep in mind Ubuntu relies on ext2 filesystem instead of NTFS file system. Windows xp may not work so use a 7 or 8 disk. You will most likely have to format your HDD to NTFS.
SOURCE: Bluetooth not working after OS re-install on Lenovo 3000 Y500 lap
if you install xp then find out the xp drivers in www.lenovo.com > select country > support and downloads > model number> etc. After downloading file >install the driver > after installation reboot your computer > after machin on you just switch on the wifi or bluetooth switch (near you laptop hinzes) and try it.
SOURCE: "Windows vista booting corrupt"
try to boot ur laptop with disc manager cd or win XP.
if doesnt works then try win 98 cd and delete ur C:/ partiton and install new vista
SOURCE: my lenovo y530 with vista will not boot. I cannot
well try f8 while booting, and choose safe mode, and try, if not you must have instalation disk for repair windows, it´s normal with virus installed.
SOURCE: My Laptop is Lenovo R500
Welcome to Fixya
Try to boot the computer in safe mode. Turn off the computer then turn it back on. keep on tapping F8 then select SAFE MODE form the selections. If your computer wont able to boot to safe mode then you have a corrupted operating system. You need to reinstall windows using the recovery disk that came with the sytem.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
