Question about Kenmore 54501 Dehumidifier
Dehumidifier not collecting moisture
We just bought a used kenmore dehumidifier, model # 2535030000, let it run for a couple of days, and it's not filling up. All the lights turn on, and the fan runs. There is over 70% moisture in the room. What might need repair or cleaning?
  • Anonymous Apr 20, 2009
    There is definitely high humidifier in our basement, and I used to need to dump humidifier 1-2 times per day. Now it runs for days, and the tank is bone dry. We have raised the room temp as suggested in manual, and have also checks drain tubes, etc. Fan runs, lights are on, and nothing helps.
  • 11 Answers
Normal 0 When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
Posted on May 29, 2009
  • jman563 May 29, 2009
    Normal
    0
SOURCE:
SOURCE: Dehumidifier does not collect water.
I had the same problem. I just narrowed it down to the humidistat by wrapping it in a baby wipe. It runs smooth now and fills the bucket....I'm off now looking for a replacement.
Posted on Aug 13, 2007
  • 225 Answers
SOURCE: Dehumidifier Does Not Collect Water
A dehumidifier is just a refrigerating machine with it's shirt hanging out and there is not much in the way of serviceable parts inside.
If the compressor runs - the throbbing sound - and it doesn't collect water then either the intake filter screen is totally clogged with fluff or the compressor has leaked it's gas away, in which case it might run continuously and get hot to no good effect.
If it doesn't run then it may be that the motor capacitor has failed, but that can soon lead to the compressor motor cooking itself; leaving you with an expensive doorstop.
The one thing you might get checked is the "bucket full" switch. There will be a floating part on the bucket which rises up when the bucket fills and eventually makes contact with another part which is connected to a small switch. If that switch has failed you might be lucky and get an inexpensive repair job done.
If these suggestions do help you solve the problem, please give my reply a suitable rating. If they do not, please add a comment with more details so I can try to help you further.
Cheers, D
Posted on Jul 01, 2008
66 chrgr
  • 1011 Answers
SOURCE: Kenmore dehumidifier runs good but does not collect water.
most likely the compressor is not producing pressures that are needed probably not low on freon .
Posted on May 31, 2009
  • 340 Answers
SOURCE: Moisture not collected
low on freon is the compressor running?
Posted on Jun 18, 2009
  • 156 Answers
SOURCE: lg dehumidifier won't collect water after running for long time
Sounds like it needs to be recharged.
Posted on Jun 28, 2009
Dehumidifier does not collect moisture. cleaned the filter and still doesn't work. fan works fine.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 22, 2011 | Kenmore Dehumidifiers
My Haier dehumidifer runs but doesn't collect any water. I have another exact same dehumidifier sitting 10 feet away and it fills up about every 24 to 36 hours so I know the conditions are that it...
heatman101
May 12, 2011 | Haier Dehumidifiers
Dehumidifier runs but extracts no water at all. room is 65degrees & humidity is 75%. no frost on coil & no moisture either. kenmore model no. 580.54501.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 15, 2011 | Kenmore Dehumidifiers
Dehumidifier not dehumidifying
heatman101 ....
May 25, 2010 | Whirlpool AD50USS Dehumidifier
Dehumidifier does not pull moisture from the air
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jul 09, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Kenmore 54501 Dehumidifier Problem
Jul 17, 2008 | Kenmore 54501 Dehumidifier
Dehumidifier switches on and off continuously
Patty - Is it possible that the dehumidifier is cycling... meaning there is not enough moisture in the air for it to run constantly.
Aug 16, 2007 | Kenmore 54501 Dehumidifier
Kenmore 54501 Dehumidifier Logo
533 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Marvin
Marvin
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
