EW30EW65SS Stainless Steel electric oven smells like burning electrical when the bottom oven is on convection broil mode. The smell comes from the air being blown out of the fan vents above both the upper and lower oven but doesn't come from the inside of either of the ovens? Any ideas?
Hello purrpplee - If the smell is coming out of the oven vent, more than likely it is something inside the oven that is creating the odor. Also, keep in mind that new cooking products can create a burning electrical odor when the bake and broil cycles are used as any residual coating or film on the oven liner and elements burns off. However, if odor increases consult a professional for an accurate diagnosis.
SOURCE: Electrolux EOB5600 electrical fault?
goto home depot,lowes and get some ceramic wire nuts and heat tape and electrical tape.cut the wires back on both sides of the terminal block.bypass the t-block and connect the wires with the wire nuts wrap the heat tape then electrical tape on each one.if you have access to a amp meter take readings to make sure the amp draw isnt too high.i would think the wires just burned up from either a loose connection or the heat of the oven.this should solve your problem.
Hey friend, thank you for your post!
I understand that your Electrolux wall oven is not heating. I would like to ask some additional questions so that I can better assist you. First, is your appliance displaying an error code of any sort? Secondly, is display on? A step you could try would be to reset your appliance, which is done by either unplugging your appliance or flipping the household circuit breaker for ten minutes. I look forward to your response to better assist you. -Matt
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
