Fan comes on /// battery is green // new can of gas, but it won't fire at all
GO TO TOOLS DIRECT.COM THE SPARKPLUG IS # 11 UNDER THE END CAP.BUT MAKE SURE YOUR SAVETY IS OK.THE SPARK UNIT ASSEMBLY IS #20 IN THE HANDLE.
You may want to check the expiration date of the fuel you are using. One of the biggest complaints I get is that their Paslode nailer won't fire. I will first check the fuel. If it is expired the tool chances for failure are significantly higher than normal. Next would be to check for spark. This can be done by removing the fuel and while listening to the rear of the gun perform a test shot. You should hear a click from the spark plug. The fan should run as well. No spark sound means the tool is either dirty and the spark can't connect with anything or the spark unit is bad. Another thing is the light in the handle. If it's green and you hear the click then that tool is dirty. Red flashes indicate the problem as being electrical.
SOURCE: Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
SOURCE: my paslode f 16 nail gun wont fire nails,new gas.
i found this happening to me and i oiled (light oil like 3 in 1) the driver (hammer) in the tip. that way it could retract and drive the next brad.
