SOURCE: Mitsubishi WS-65807 and blue-ray compatibility
that tv set is only good enough to receive a 1080i signal at the DTV INPUT. unless you can change the output of the blue ray it will be outputting 1080p
SOURCE: Mitsubishi Ws -65313 65in
Follow the steps below to reset system defaults to factory settings. . Press the MENU button followed by number buttons , ,and on the remote control. Result: The above steps activate the Reset System Defaults menu screen . Press the ENTER button on the remote control. Result : The settings reset to factory defaults. . Press the HOME or MENU button on the remote control to return to the HOME or MENU screeen. IMPORTANT: This function is not recommended unless it is mandatory to reset system defaults to factory settings. This operation CANNOT be undone and all customs settings will be erased.
If you are unable todo that id suggest you contact Mitsubishi, your dealer, or a local professional.
Main support number 800-332-2119
Support FAX (714) 229-3854
Email support[email protected]
SOURCE: mitsubishi ws-65807 no sound or picture
Something related to the video boards. Check all inputs first, then check ribbon cables to the video board. Be careful of high voltage if you open the cover.
I suggest to visit the website of manufacture to have both question answered . thanks
SOURCE: mitsubishi ws-65807 v17 chassis
go to this websight leave an e-mail with your model number and let them know you need a signal board and they should be able to help you plus there prices are very reasonable and they also offer free online tech support to their customers
http://servicemanuals.vstore.ca/
