eMachines eMD620-5133 Notebook Logo
paul buck Posted on Jan 30, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i go to displays on my note book it shows up error system 32 rundll 32.exe
I have tryed on internet to solve this prob but only videos shown are on pc and tell me i need a windows 7 cd which i dont have and no were to put cd as it is a note book pleases help
Anonymous
Level 2:
Sergeant:
  • Expert 378 Answers
  • Posted on Jan 31, 2013
Anonymous
Expert
Level 2:
Sergeant:
Answers
378
Questions
Helped
78240
Points
816
In your sart menu using the search tool search for rundll 32.exe
Windows xp ulcpc note book emachines..system 32 rundll.exe
system 32 rundll.exe b> To resolve these problems, follow these steps: Restart the computer in safe mode: Restart your computer. While your computer is starting, repeatedly press the F8 key on your keyboard. On a computer that is configured to run under multiple operating systems, you can press the F8 key when the Boot menu appears. When the Windows Advanced Options menu appears, select an option, and then press ENTER. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom of the screen, select the installation that you want to start, and then press ENTER. Open My Computer, and then open the C:\Windows\INF folder. Right-click the sr.inf file, and then click Install. When the installation process has completed, restart the computer. If you continue to experience one or more of the problems that the "Symptoms" section describes after you have completed the previous steps, restart the computer in safe mode, and then reinstall Windows XP SP1a or install the latest Windows XP service pack.
To obtain Windows XP SP1a, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?FamilyID=0136e5f8-1684-4202-b2d0-c6a43430f12a&displaylang=en (http://www.microsoft.com/downloads/details.aspx?FamilyID=0136e5f8-1684-4202-b2d0-c6a43430f12a&displaylang=en) For additional information about how to obtain the latest Windows XP service pack, click the following article number to view the article in the Microsoft Knowledge Base: 322389 ( http://support.microsoft.com/kb/322389/) How to Obtain the Latest Windows XP Service Pack
My windows xp no longer supports the system 32 rundII.exe connections
The rundll.exe is a critical core system file. If it has been corrupted then entire Windows is severely affected and it's too late to fix it. Make a backup of all your files while you still can and reinstall.
Rundll 32.exe
hello
Download Rundll.32.exe Repair Tool
Compatible: Windows 98, 2000, ME, XP, Vista, 7 (32/64)
How Do I Fix "Rundll.32.exe"? (Instructions) Please follow the following 3 steps to eliminate your problem:
STEP 1: dicon.png Download the repair tool
STEP 2: Install and open the tool
STEP 3: Scan & repair the found errors
please rate my service
After starting the laptop it showing amessage like this ''RUNLL There was a problem starting winpxs32.rom The specified module could not be found...
just found this on the internet not sure if it will work for you but have a read up about it.
Rundll problem issues are caused by misconfigured system files. Rundll problem usually happen when the computer's registry system overloads with to much data, or when certain system files become missing or broken.
The Rundll problem issues are easy to repair. By downloading and running the registry repair tool System Optimizer, you can quickly and effectively fix this problem and prevent others from occuring. Simply click the links below for your download.
Download & Install System Optimizer.
Note:If the download link doesn't work you may need to Download it from a mirror
  • Step 2:
    Click the "Quick Scan" button.
  • Step 3:
    Click the 'Repair All' Button to Repair Your PC.
  • or try this link first..
  • RUNDLL There was problem starting winpxs32 rom The specified module could...
    How do i remove run.dll2 from my computer?
    Rundll.exe files are programs that are directly tied to the registry on Windows computers. Dynamic Link Library (DLL) files contain libraries of information used by other programs running on your computer. They were originally created in order to help computer programs run faster on the Windows operating system. When a DLL file is corrupt or missing, a Rundll error will be generated. Normally when a rundll error is generated it is related to malware.
    1. Note the process that is generating the Rundll error by examining the last file name in the error that ends in ".dll."
    2. Open the service configuration program on your computer by selecting the "Start" menu and typing "command" in the search text field. At the DOS prompt type "services:msc" and click "Enter."
    3. Select the DLL service from Step 1. Right click the service name followed by the "Stop" menu button. Exit the service configuration program.
    4. Open your computer's registry editor by typing "regedit" at the DOS prompt and navigate to the Rundll registry key by typing "Microsoft\Windows\CurrentVersion\Run" in the Search field.
    5. Select the registry key returned and in the value associated with the registry key, confirm it ends in the same DLL file name found in Step 1. If it does, single left click the value and Press the "Delete" key. Exit the registry editor.
    6. Restart your computer and the Rundll error will be corrected.
    Save a tree.
    7helpful
    2answers
    Rundll32 exe-entry point not found the procedure entry point_except_handler3 could not be located in the dynamic link library vmsvcrt.dll
    Just visit this site...
    http://www.fix-all-dll-errors.com/vmsvcrt.dll/
    this will help in case of missing or downloading dll's .
    helped in my prob. :)
    1helpful
    14answers
    Top eMachines Computers & Internet Experts
    Andrew Chrostek
    Andrew Chrostek
    Level 1 Expert
    Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
