Question about HTC HD2 Smartphone
My htc hd2 will not turn on or charge it just has a circle on the screen and numbers on the bottom left hand side when i plug the charger in can you help me please
    Top Expert:
  • 12,223 Answers
1) try to use another charger or 2) use the USB system see the 3) test the batteries if o.k or drained or faulty clean the contacts batteries for dirty or corroded. see diagram attached.God bless you
Posted on Jan 30, 2013
SOURCE:
  • 56 Answers
SOURCE: HTC HD2 they gave me the wrong download for english
Well with the phone turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then press the END/POWER button shortly and release it. You will then see a message on the screen asking if you're sure about resetting it. If so press the VOLUME UP key. It should boot shortly after that.
Posted on Jun 02, 2010
casouzaj
  • 1118 Answers
SOURCE: HTC HD2 and PC Suite
You must intall either ActiveSync (if your PC has Windows XP) or Windows Mobile Device Center (in case it has Vista or 7). You can download any of them from this location.
Hope it works for you.
Regards, Carlos
Posted on Jun 30, 2010
  • 318 Answers
SOURCE: htc hd2,phone battery died,put on charge and turned it
take a look at this link i found, it shows you how to do a soft reset on your htc hd2:
http://www.htc.com/europe/howto.aspx?p_id=297&id=181
HOPE THAT HELPS.
Posted on Jul 07, 2010
WIMAGE09
  • 282 Answers
SOURCE: my htc hd2 wont start up keeps turning itself off
http://www.hardreset.eu/htc_touch_hd_hard_reset_soft_reset_en.html
try to perform a hard reset and see if that will fix your problem. But before you do ill have tell you will lose all your information on that phone once its hard reset.
Hope this will help you...thanks
Posted on Oct 29, 2010
cardenderek
  • 783 Answers
SOURCE: HTC HD2 not "booting up" I have an HTC HD2
take it to your service provider they will fix your problem on the spot usually or order you a new one free of charge. -Derek
Posted on Jan 10, 2011
Why wont my HTC HD2 T8585 turn on
I have the same problem on my HTC HD2 T8585
I thought it was a battery, but I bought a new battery. The problem comes on when the charger is pluged and then shuts off in seconds and turn back on and to the same thing over.
Jul 23, 2012 | Cell Phones
How to change to english language my htc hd2?
Before doing it please take a backup of your phone.
Do HARD RESET (Go setting/in bottom- Menu/All setting/system/Clear storage/put the number 1234 then ok....And the other way for Hard Reset is put OFF the Device then press and stay together volume control UP and DOWN key (See in Left side of the device) and CALL END key .... when BLUE disply is ON, press Volume UP key .... then press again volume Up key...Now Device start Reset ......
After reset windows the device request you to select the language of HTC Sense (more than 8 language included in every HD2). If included English language in your device select it and solved your problem.
if it helps please give me a vote and 4 thumb rating.
May 26, 2011 | HTC Cell Phones
HTC HD2. Just out of warranty. Added Android 2.2. Loaded & ran Android Market place apps. No physical damage at all. No dropping on floors, etc. Have two new batteries, fully charged, spare...
check to see if its not your battery charger they go bad most of the time before the phone does if im wrong what will you loose you will have a back up charger.
Feb 11, 2011 | HTC HD2 Smartphone
Jan 10, 2011 | HTC HD2 Smartphone
My htc hd2 wont turn on at all
Hello Friend OK open up the back cover under the battery on the left side is a small hole/button get a pen and press it then turn on your phone. :)
Sep 08, 2010 | HTC HD2 Smartphone
Htc hd2,phone battery died,put on charge and turned it
HOPE THAT HELPS.
Jul 06, 2010 | HTC HD2 Smartphone
How should i format my htc hd2 cell phone
hello,you can kindly follow the instructions below to reset your mobile phone totake it back to it's factory default settings,this will automatically make you loose all the datas you have on the phone,so before you intend to do the reset format,i will advice you do a file or data back up on your system so as not to lose your informations
1.with your thumb or finger open the back cover by lifting up the left side of the cover.
2.the reset botton is located at the bottom left below the battery compartment and the simcard slot.use a small object with an unsharp,pointed tip,such as a toothpick to press the reset botton.
your phone restarts and dislpays the home screen,
3.to replace the back cover,secure the right side of the back cover first and then press down the cover into place.
please kindly rate this solution if it's helpful,
take care.
Jun 14, 2010 | HTC HD2 Smartphone
Won't turn on or charge
Press Mode (bottom left side button) and Reset (left front button) simultaneously, let go, then press On (top left side button).
Jul 28, 2009 | Garmin Forerunner 305 GPS Receiver
Only works when adapter's plugged in.
try plugging and unplugging the charger/ac adapter several times to see if the switch that is built into the jack might be stuck from dirt or corrosion.sometimes you can take a toothpick and get them unstuck too.
Sep 25, 2008 | Icom IC-R5 Handheld Scanner
HTC HD2 Smartphone Logo
64 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
rrackman
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
