Question about Pioneer PureVision PDP-5040HD 50 in. Plasma HDTV
Pioneer PDP 5040 Plasma Stays on Standby.
When I power on both the media receiver and and the display, the display stays stuck with no sound or video, only showing the power (green LED) and standby (red LED ) lit up. Both these remain lit, until I decide to shut it off. The media receiver shows a green (healthy?) Light in all of this. Since I don't have a service manual, I cannot diagnose where to begin looking. There are no error flashes either, Right when I power up, both lights on the display turn on, and stay on...
  • john Jan 30, 2013
    I immediately thought of the power supply, but I cannot find one anywhere. I wonder if Pioneer used similar power supplies for other plasmas?
  • DENNIS MITCHELL Jan 31, 2013
    check ebay or do a random internet search type in power supply and the model # of your tv
    Genius:
  • 1,003 Answers
Replace the power supply on the plasma TV
Posted on Jan 30, 2013
2 Suggested Answers
SOURCE:
SOURCE: I have a Pioneer PDP-R05G
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
http://www.pioneer.owner-manuals.com/PDP4360HD-service-manual-PIONEER.html
service manual link above,
as an aside here, sometimes things in storage can quickly degrade especially big low value capacitors, these increase in internal resistance, and all sorts of problems ensue, this is why, say, military things are cycled at least weekly when in "Moth balls" to prevent exactly this.
Posted on Mar 12, 2011
Pioneer plasma light wont come on just stays in standby and when i push the standby button it comes on
Sounds like main board fault. Contact the service center.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 28, 2014 | Pioneer PDP-5080HD 50 in. Plasma HDTV
I have a pioneer pdp 5040 plasma and it just died on me. It will turn on then turn off after 3-4 sec. The standby light flashes 3x pauses then flashes 3x again, can I fix this
PDP-5040 turns on then off after 3-4 seconds / display in upper right corner says user full and record timer led is lit on box / rrepairable?
Sep 27, 2010 | Pioneer PureVision PDP-5040HD 50 in....
My pioneer plasma PDP 5060HD Media Center control box has red blinking light, blinking once every second. No power to plasma display and unable to power on media center box. Recycled power to both plasma...
lenwas,
I have the exact same problem with the same model tv. It just stopped working, tv has no lights or evidence of power and the red standby light on the media center flashes without any other function potential.
I checked the internal tv fuse and it was measuring continuity.
If you figure anything out I'd be interested to hear it.
Tom
Jan 05, 2010 | Pioneer PDP-5060HD 50 in. Plasma...
Pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Mar 29, 2009 | Pioneer PureVision PDP-4340HD 43 in....
Can I use media receiver PDP-R04U with PDP-436PU display?
You need the pioneer media cables hooked up to the media receiver to the plasma unit itself. each end has 2 different plugs. one has 2 thumb screws and the other is a squeezable end that clicks into place. They MUST be on before you plug in any power what so ever!!!! And yes, other information is being passed through.
C-Dog
Sep 18, 2007 | Pioneer PureVision PDP-4340HD 43 in....
Pioneer PureVision PDP-5040HD 50 in. Plasma HDTV Logo
710 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
