Question about HP Compaq nc6120 Notebook
I have hp compaq nc6 120 model laptop but i dont have a audio driver installed in it, which audio driver will suit to my laptop?
Intel celeron m370 processor,512mb ram,30gb hdd,
    Sergeant:
  • 378 Answers
SOURCE:
antiochpc
  • 1314 Answers
SOURCE: NEED TO UPGRADE HP NX9040!!!
www.tigerdirect.com
www.newegg.com
Oh and please take a moment to rate this solution as fixya! Thnaks! :c)
Posted on Jan 03, 2009
  • 10 Answers
SOURCE: audio driver installation software
Enter your model number here.. (remove the space in the url)
http://welcome.hp.c om/country/uk/en/welcome.html#Support
Posted on Jan 25, 2009
  • 211 Answers
SOURCE: I lost my drivers CD and i want to install my
Here are drivers for WinXP,
Here are drivers for Vista.
Just click Download on every driver and then run downloaded file.
Or you can Download all drivers and burn to cd or usb pen and then install one by one in same way.
Note: install in this order if XP:
1. Chipset
2. Microsoft Universal Audio
3. Modem
4. Audio
5. everything else
If Vista:
1. Chipset
2. everything else
Posted on Mar 28, 2009
SOURCE: Upgrading My hp530 laptop
It is working.
Tested first with one new module with 2GB RAM, then with 2 modules, 2GB (new) + 1GB (original). Post and Windows are showing 3GB.
The HP 530 notebook is working OK.
Posted on Mar 12, 2010
  • 4044 Answers
SOURCE: i am having hp 530
Unfortunately I would have to say no, you won't be able to upgrade the processor. I located a user manual at
http://h18000.www1.hp.com/products/quickspecs/12722_na/12722_na.PDF
According to specifications you can increase the Ram to 2 MB and the hard drive should be a 120GB hard driver Sata
System Memory 1024-MB 533/667-MHz DDR2 SDRAM in one slot
Two SODIMM slots; supported memory 2048 MB2
Operates at a maximum of 533-MHz with 667-MHz memory
Hard Drive 120-GB3 5400 rpm SMART SATA
The processor will be limited to what the motherboard can support and it was designed for that 1.6 Ghz processor. Unfortunately it is very difficult to upgrade processors in laptop machines. I do have to ask how old this machine is. The specification indicates MegaBytes of ram and this is actually very little Ram in today's computing world. Most machines support at least 2 gigaBytes of Ram to start with.
Posted on Nov 20, 2010
I purchased a desktop comp Assus motherboard intel celeron 1.8 kingston 1g memery500 sats hdd. does not boot cpu makes a tik tik sound
clean the RAM and insert it. if not change the RAM. If problem not solved, you have brought a G41 Asus motherboard, which is not compatible with celeron processor. insert a pentium dual core processor and it will work.
Aug 28, 2011 | Computers & Internet
What is the processor type and speed, RAM size and Hard drive capacity of packard bell R1005 laptop
It has a Celeron M processor, with 1500MHz clock speed, 512MB of RAM and a HDD capacity of 40GB and a 15.4'' screen.
Jan 29, 2011 | Computers & Internet
I have pentinum4 intel(R) celeron processor 1.3 GHZ processor. I want to increase the speed of my processor without any hardware change. I have 40 GB HD & 512MB with windows XP RAM.plz help
you cannot change the speed of your processor unless your processor supports overclocking. however your processor does not support that.
if your computer is running slow try upgrading the RAM to 1GB.
also check to see whether you have unwanted applications running in the background
Jan 25, 2010 | Intel Celeron D 335, 2.8 GHz Processor
851 MHz Celeron Processor
*********** board will support a max of 1GB of RAM. Your processor is an Intel at 1.8 GHz. The preceding is only true if your PC is the Emachines T1840 as you chose in the category listing of your post. Again if that is true, you can achieve the max RAM by installing a 512MB stick in each of the two memory slots.
Good luck.
PS: Gdlkn84as528 is correct in assuming that a less than 1.3GHz Intel processor would be a P3 or equivalent processor. So which is it, it can't be both ways?
Sep 18, 2009 | E-Machines -T1840-CELERON-1.8GHz,40GB...
I want to upgrade my hard drive.
If you have 50% or more disk space free then you may not need a larger hard disk at this time. If you have 512Mb of RAM, you can get better performance with 1Gb or better still 2Gb of RAM if your Acer can support more than 1Gb of RAM.
Jun 09, 2009 | Acer Aspire 5315 Notebook
My PC is not installing XP service pack 2
You'll need to upgrade your RAM, minimum requirements for windows xp is 512MB.
for the best price on ram go to http://www.pricewatch.com
i would recommend at least going to 1 or more gig.
Mark
Mar 27, 2009 | Intel Celeron 2.4Ghz Socket 478 CPU (...
Asrock Motherboard problems with SATA HDD
It is possible that you are trying to use a SATA II HDD in a system that supports SATA. SATA II devices are not backwards compatible usually,
Dec 20, 2008 | Asrock P4V88 (P4V88 RAID) Motherboard
HP Compaq nc6120 Notebook Logo
73 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
