Question about HTC P3300 Smartphone
Disconnecting In the Home screen and across the top are some icons which show signal strength and data connection. The data connection on other HTC P3300 we can click on and it shows if connected or not and if connected allows us to 'disconnect'. This particular HTC P3300 only allows to go toComm Manager or Settings. To disconnect I have to go to Comm Manager and then click the data push option, then put tick in the connection I want to select and the click Disconnect. How to I get back the quick option in the Home Screen??????????? Help as I am having a really bad day so far and it's only 11am Thanks in advance
SOURCE:
Techno777
  • 47 Answers
SOURCE: not able to set up GPS in my HTC p3300 in india
It sounds like your not able to access the internet on the device , try going to a normal webpage and then you can check if it loads it most probably wont. if that is the case you will need to contact your network to get the settings. ( Most networks will brand the device with there own name it can be helpful to find what this is before calling .) once you have done this then you will be able to download the quick gps settings . The special GPRS mentioned above is only the networks name for there GPRS service.
After this is done you may notice that you still arent able to use your GPS to find your location that is because you need to select the port that the GPS device is on
1.Tap start > settings
2. Tap the system tab
3. Select the GPS option
4. In the drop-down box that is entitled GPS program port select COM4
5. Tap Hardware tab , Gps hardware port should be ( None ) and baud rate 4800
6. Tap access tab and then select manage GPS automatically tickbox
7. Now click ok then x
You will now need to setup MAPKing to use COM port 4 as the GPS device this will now allow you to use your GPS properly
Posted on Mar 13, 2008
  • 34 Answers
SOURCE: HTC TyTn II data connection problem
It keeps connecting because an application keeps wanting to access the internet.
Make sure you set your email to manually download messages.
Turn the Weather Tab off in HTC Home Screen as it automatically downloads the weather.
Turn off "QuckGPS"
Disable Error Reporting to Microsoft in the System settings
Also remember MMS messages will require internet connection.
Everytime you send a MMS or receive a MMS your phone will connect to the internet.
Posted on Jul 08, 2008
SOURCE: Alltel hTc touch phone
I am told "It's Revision A EVDO, meaning more speed. There's information on Wikipedia about it if you want to read up. It just means if you were to tether or if you use Opera to browse the web it would be faster connection speeds."
Posted on Mar 31, 2009
chalam
  • 4 Answers
SOURCE: Unable to connect HTC P3300 via Active Sync.
if you are using XP,install ACTIVE SYNC 4.5. if you are using VISTA or WINDOWS 7, no need any sync software. plug in the HTC to your laptop. right click on MY COMPUTER and select MANAGE. in the window that appears now, on the left hand side select DEVICE MANAGER. now on the right hand side see if you have any yellow colour icons. if YES,try to update the drivers. if nothing works out, try another PHONE to connect and use your phone to connect to another laptop. atleast this will give some idea as where the problem lies
Posted on May 27, 2009
  • 378 Answers
SOURCE: CALL CONNECTION PROBLEM
try resetting ur mobile to company setting. dont install 3rd party softwares
Posted on Aug 14, 2009
Why does my network connection on my powerspec computer keep disconnecting unexpectedly
Normally this is either because the signal strength from the router is weak, and also if the signal strength is not at its highest then the data can be interrupted by other incidental high power equipment being used nearby. This can be a vacuum cleaner, washing machine etc.
Sep 27, 2014 | Computers & Internet
My ipod recognises the wifi network but can't connect
The iPod touch has the ability to connect to Wi-Fi networks, giving you access to information while on the go.
The iPod detects both protected and unprotected networks, and can remember which Wi-Fi networks you have used before, eliminating the need to enter passwords more than once.
Your iPod touch should automatically detect wireless networks, but you can also manually connect to a network or switch to a new one.
Tap the "Settings" icon on the home screen and tap the "Wi-Fi" button.
Tap the "On/Off" button to turn your Wi-Fi on. Press the "Home" button to return to the home screen.
Tap the Safari Web Browser application or any other application that requires Internet access.
A list will automatically open on your screen that names all available networks.
Tap the network you wish to use from the list.
The networks listed are all wireless networks detected by the iPod.
Protected networks will have lock icons to the right of their names.
Enter the password if the network you have selected is protected.
Your iPod touch will store this password for future use.
Type in the name of the network you wish to use if it is not listed.
A network that is set to not broadcast will not show up on the list of available networks.
Check the top left of the screen for the Wi-Fi icon to be sure you have connected.
The number of bars on the icon indicates the strength of the signal.
Manually Connect
Tap a network listed under "Choose a Network..."
A network set not to broadcast will not show up on the list of available networks.
http://support.apple.com/kb/HT2031
Nov 15, 2013 | Apple iPod touch
Ipod will not connect to wifi
Connect to WiFi for Your Apple iPod touch b> The iPod touch has the ability to connect to Wi-Fi networks, giving you access to information while on the go. The iPod detects both protected and unprotected networks, and can remember which Wi-Fi networks you have used before, eliminating the need to enter passwords more than once. Your iPod touch should automatically detect wireless networks, but you can also manually connect to a network or switch to a new one.
Tap the "Settings" icon on the home screen and tap the "Wi-Fi" button. Tap the "On/Off" button to turn your Wi-Fi on. Press the "Home" button to return to the home screen. Tap the Safari Web Browser application or any other application that requires Internet access. A list will automatically open on your screen that names all available networks. Tap the network you wish to use from the list. The networks listed are all wireless networks detected by the iPod. Protected networks will have lock icons to the right of their names. Enter the password if the network you have selected is protected. Your iPod touch will store this password for future use. Type in the name of the network you wish to use if it is not listed. A network that is set to not broadcast will not show up on the list of available networks. Check the top left of the screen for the Wi-Fi icon to be sure you have connected. The number of bars on the icon indicates the strength of the signal. b> Manually Connect Tap the "Settings" icon on the home screen and tap the "Wi-Fi" button. Tap the "On/Off" button to turn your Wi-Fi on. Tap a network listed under "Choose a Network..." The networks listed are all wireless networks detected by the iPod. Protected networks will have lock icons to the right of their names. Enter the password if the network you have selected is protected. Your iPod touch will store this password for future use. Type in the name of the network you wish to use if it is not listed. A network set not to broadcast will not show up on the list of available networks. Check the top left of the screen for the Wi-Fi icon to be sure you have connected. The number of bars on the icon indicates the strength of the signal.
b>
Feb 06, 2013 | Apple iPod Audio Players & Recorders
BlackBerry Curve 8520 signal swing
#1 Your BlackBerry does not have sufficient Power
Check the battery charge level as shown by the battery icon on the top left of the home screen. No Power - Battery Charge Indicator does not show a charge or is very weak. The battery icon may be red. Charge the battery.
#2 You are Out of Network coverage area
Check the Signal Strength Indicator on the home screen. (1 to 5 bars, as shown below, indicating signal strength). If there is no signal, you may be out of range of the network.
If you are sure you are in range of the network, but show no signal strength, press Alt-Right Shift-Del at the same time. This will cause the BlackBerry to reacquire a network connection.
The process for this procedure is:
  • Press Alt-Right Shift-Del (The Del key is also the Backspace key.)
  • The screen will go blank, and an hourglass will appear. Wait for the hourglass to go away.
  • The startup screen will appear. Wait for it to go away.
  • A screen that says Verifying Security Software will appear. Wait for it to go away.
  • Check the Radio Tower icon.
If you are in Coverage Area of your Service Provider, You will get the network.
#3 Your Data plan is switched Off.
Feb 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
Have HTC hero, it will no longer connect to data/internet, I tried disconnecting and reconnecting thru the options, but it still will not pull up web page on browser or weather for that matter on front...
It sounds like you have turned off the Mobile network option (that is the data option for Sprint, other carriers might be different).
Try this, add a widget to your screen that will turn on the data connection:
-long press on the home screen > Widget > Settings > Mobile network
This will place a widget that will allow you to turn on and off the mobile network. Make sure it is on and then try your connections again.
Good luck.
Oct 09, 2010 | HTC Hero Smartphone
Aug 14, 2009 | HTC Touch HD Smartphone
HTC Touch Dimond displays Roaming symbol E beside Signal strength
yea i also have the same problem even though i have my data switched off nd no gps etc. wont i b charged for the e symbol meaning it uses data even thou i have data switched off? this is really weird someone please help us out. thanks
Jun 15, 2009 | HTC Touch P3450 Smartphone
Mar 15, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Can't get it setup to work without being plugged in to my laptop
If you have Windows XP and there's is no extra security set up on the router then connecting is easy.
In the bottom-right corner you'll see a small icon that looks like a computer. The screen is likely blue on it. Additionally there are two faint crescents near the top of the icon. That's the Wireless Zero-Configuration tool. If you double click on that icon a window will pop up showing the names of nearby connections, their signal strength, and whether or not security is enabled. By default the name of the DI-524 is "default." If it is not secured, click on on and then click the connect button. Windows may then ask if you want to connect to the unsecured network. Click on Connect Anyway and the configuration tool will connect you to the router.
May 30, 2008 | D-Link AirPlus DI-524 Wireless Router
HTC P3300 Smartphone Logo
42 people viewed this question
Top HTC Computers & Internet Experts
robert roberts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
