SOURCE: Blurry Pictures
Contact Customer Support this is possibly a CCD problem- they may still fix it.
SOURCE: D50 with a new 18 -200 Nikon lens
Is the Auto/Manual Focus switch turned to Manual? This can easily be moved without realising that you have done so.
If not, get it checked out under Warranty. If you try to do anything yourself you will void the Warranty.
Good luck.
SOURCE: nikon 18-200 mm vr lens not auto focusing on my nikon d200
lets start with the basics, try hard reseting it and try again, if that doesnt work then
try upgrading your firmware (if possible on your camera) and if that doesnt work then it may be the lens, but dont forget to spend a few hours trying to find a option for it in the meny
SOURCE: Nikon 18-55mm AF-S/ VR lense shudder?
I believe you're hearing the VR in the lens adjusting. Try turning the VR off and see if you hear the sound. If not, then you have a normal operating lens.
SOURCE: Nikon D60x Blurry night pictures
Try switching to Shutter Prority (S) with a fast shutter speed.If the light is not so good, up the iso to 800 to gain that faster shutter speed..
You do not say the lens in use ? if VR, make sure its switched on or use a tripod.
Hope this helps
