I left it for two weeks while off n wen I switched it on it said test mode n turned off
There are few things you could try. Make sure you try from top to bottom and one method at once
Method 1 > Factory reset your device.
Method 2 > Flash an updated firmware
Method 3 > This requires some technical assistance. you better hand it over to a skilled technician as this deals with hardware level repairing
SOURCE: nokia 3110 blinks thrice and gets switch off again
no dude......i cant go inside my mobile itself......hw to update the software and name????
SOURCE: My Nokia 1112 displays 'Test mode' only and doesn't switch on!
charge your mobile and while charging try to turn on.make sure the charger is connected properly. else u need to check on the charging pin in the mobile.
SOURCE: my nokia 1209 mobile when switched on 'test
i have nokia 1209 model mobile phone when i switch it on the phone is asking the security code if i enter 12345 its showing wrong code or invalid so wt i should do now
