EHow says: Electrical power is easily conducted through a moist or wet environment. When wood fibers contain moisture it can also conduct an electrical signal or voltage. This allows the moisture meter to act as a signal generator. The signal generator will output a small voltage into the wood fibers. The small voltage is typically supplied by a battery. The moisture meter contains an internal circuitry much like an ohmmeter. The ohmmeter reads the amount of resistance that an electrical circuit may employ in conducting electricity.
Read more: How Does a Moisture Meter Work? ' eHow.com http://www.ehow.com/how-does_4924697_moisture-meter-work.html#ixzz2JRaS12Xt
