My Sony Ericsson W960i Cannot switch on
Hello:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
SOURCE: sony ericsson W960i cell phone,
try dropping down ur cellphone in a 10 cm ht..then it will work..its true
SOURCE: sony ericsson w960i touch screen doesnt work
Yes it can be fixed but you cannot fixed it by yourself, you will need software and flashing tools to do that or worst case scenario is that you might replace some damaged part on it, but it can be fix
just bring it to a cellphone repair man and will handle the problem
SOURCE: w960i 8gb built in memmory not showing and cannot access
Go to Control Panel>Device>Storage Wizard.
The wizard shall help you view and release storage media for your phone.
Hope this helps. =)
SOURCE: my w960i while loading to boot on it turns black screen.Until I r
A month ago, it happened to my phone too. I got it reprogrammed at a local repair shop for only $10. The repair man says the problem is brought about by over charging of batteries or by downloading of certain apps which eat up a huge amount of the phone's 8GB internal memory. So he advised me to be careful so it won't happen again. I hope this helps. =)
