Question about Raymarine RL70CRC GPS Receiver
Raymarine RL70CRC GPSRadar
I have recently been having a problem with my CMap Cards seems the charts is not recognized by the unit. sometimes is shows correctly mostly the unit turns on and will not show any chart details as if not card is in the reader. Sometimes it is working correclty but when I change the range or hit another soft key button the unit resets to same problem, chart? Very frustrating and could be dangerous if it happens at a bad time. Has anyone seen this. I have tried doing a full reset of the unit, cleaning the card contacts. Could it be some kind of fault in the wiring or the connection box? The data boxes seem to be showing correct position and heading etc. Radar work fine? Any help diagnosing would be appreciated.
  • 16 Answers
Hi Matt,
There is a feature in these chartplotters called "Plotter Mode" that is often misunderstood and causes the exact problem you describe.
Press menu.....chart setup.....and scroll to the bottom until you see Plotter Mode in the list of options. It should be set in the OFF position.
If you have more than one display networked onboard check the setting in each one invividually.
What Plotter Mode does is allows the chartplotter system to access range scales not supported on the chart. It is not normally used for map-based navigation but more so for chartless electronic plotting (it can display routes, waypoints and track-recorder breadcrumbs.) open-ocean cruising, or for ultra-precise GPS operations (like a precision anchor drop, finding a very specific location etc. When plotter mode is on you can zoom in to a very, very small working area. The indicator it is enable is the cross-hatch background on the screen, the lack of map information, and the NO CHART DATA watermark on the screen.
Posted on Dec 28, 2007
  • 12,061 Answers
It could indeed be the "Connection" I would check these out properly, but with such a "Mission Critical" device I for one wouldn't muck arround, and get it back to the manufacturers and have it "Serviced"
Posted on Jul 31, 2007
SOURCE:
Chart details not appearing after removal.
Same problem I had. After resetting unit and checking CF on another unit, Raymarine tech. said, the reader is not working. All pins seems to be OK on first look. I opened unit by removing several screws in front, gasket and the whole chassis from the case. Simple repositioning of pushed down pins from inside into the Compact Flash corrected contact problem of reader. Since then, I never removed CF. It seemed, after several reinsertions of CF, I pushed down two pins in CF slot.
Jul 26, 2010 | Raymarine C120 GPS Receiver
How to hookup RL70CRC to boat wired for C70
There are 5 wires running out of the antenna and the 5 wires that you need to connect.
Oct 30, 2008 | Raymarine Computers & Internet
Goes to standby mode than unit not spinning C70
Press and hold the next grey button to the powerbutton than the plotter maks a factoryreset. Software shoud be 4.29
Oct 12, 2009 | Raymarine RL70CRC GPS Receiver
I Have a Raymarine Radar RL70CRC HSB2 the
If both plotter works but they have no comunikation
RESET the RL 70 AND L760
This is how it works
press the powerbutton when you have picture press the menu bottom
than systemsetup and than four seconds the menu bottom.
Do this on both plotter normaly after this it works again
Jun 11, 2009 | Raymarine RL70CRC GPS Receiver
Can a Raymarine SL70 screen be replaced, mine has
You may be able to send it in to Raymarine however you need to call to be sure. The older models are often abandoned and they may not work on them any longer.
May 10, 2009 | Raymarine RL70CRC GPS Receiver
Plotter Rl70c no image
sounds like it died...i happen to have one for sail with 4k dome
Sep 19, 2008 | Raymarine RL70CRC GPS Receiver
Rl70c raymarine depth finder problem
fish finder transducer needs to be on before you boot your system. check your hsb cables and termination
Jul 12, 2008 | Raymarine RL70CRC GPS Receiver
RL70CRC crashes with new "Wide" C-map cartridge
get a new burn on the chip, I have seen this issue on a particular burn.
Mar 22, 2008 | Raymarine RL70CRC GPS Receiver
Replacing an RL-70 with an RL 70-CRC
I did exactly what you wish to do a couple of years ago. It was a 5 minute job, cut out the same except the new unit needs a little more space behind and it was a plug for plug swap. Works great and swaps data between the matching chart plotter to give chart overlay on the radar
Richard
Jan 03, 2008 | Raymarine RL70CRC GPS Receiver
Raytheon RL70C and/or RL70CRC
Are you still having trouble with this one?
Oct 16, 2007 | Raymarine RL70CRC GPS Receiver
Raymarine RL70CRC GPS Receiver Logo
436 people viewed this question
Top Raymarine GPS Experts
gerd butler
Level 1 Expert
Ekse
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
