1998-2003 XJ-Series Supercharged Rear Back Coil Spring Set Suspension Damper Logo
A
Anonymous Posted on Jan 30, 2013
WHERE ARE THE bogs and sputters - 1998-2003 XJ-Series Supercharged Rear Back Coil Spring Set Suspension Damper
Bruce
Level 2:
Sergeant:
  • Expert 311 Answers
  • Posted on Jul 28, 2014
 Bruce
Expert
Level 2:
Sergeant:
Answers
311
Questions
0
Helped
104285
Points
771
There ARE NO BOGS and SPUTTERS with or in a Jaguar.
It is the finest automobile ever built!
I'm working on a 2006 Suzuki forenza. I have new plugs and wires, timing belt, camshaft and crankshaft sensors, catalytic converter, and the first o2 sensor from the engine. it runs fine in park when I...
USA car? y/n what engine,?
sputters, not bog, do you have full power wide open throttle.
sputters means to mech, MISFIRING
if it is misfiring the OBD2 scan tool tells you it is, and even which cyclinder fails like P0301, = cyl, #1 misfire.
what is and ICA, there is no ASE listing for ICA< so you typed it wrong, my wild guess, Idel Air speed controller is yes ,that is not cause of sputter ever.
Bogging means like dragging 10,000 pound weight or pulling 2000lb boat up PIKES PEAK, CO.
here is a list for misfire, (takes tools and skills and tests to find it)
  • bad fuel (car sat over 1year not driven?)
  • bad spark
  • low fuel pressure if sputter means bogging and not misfire.
  • EGR stuck open. (if it has one , no engine stated)
  • clogged or leaking fuel injectors, will make misfire.
if bogging , add, bad MAF sensor, and low fuel pressure.
When I start my 1996 Honda accord the engine seems to sputter rpm gauge revs up on its own and spits and sputters as I'm driving down the road
My sputtering & stalling 1993 Honda Accord - YouTube
? 2:12
https://www.youtube.com/watch?v=Ki2H9aq8Xis
Jun 23, 2011 - Uploaded by mdpbfly
My sputtering & stalling 1993 Honda Accord ... 1996 Acura Integra, hesitation accelerating & misfire. ... 1993 Honda Accord Start Up and Review 2.2 L 4-Cylinder ... SIR B16A Engine sputter/ power loss at higher RPM - Duration: 1:14. by ... 1994 Honda Civic Check Engine Light Code Retrieval Tutorial ...
All comments on How To Solve Honda Idle Problems ...
https://www.youtube.com/all_comments?v=L788jKEVblY
What should I do if once I turn on my Ac my idle drops as if it's gonna die, and .... to a complete stop the rpms start going up and the car accelerates on its own. ... Honda Accord LX, and my Honda just started sputtering in idle. check engine .... My cousin replaced my radiator on my 90 civic and since then my temp gauge is ...
Acceleration Bog/Sputter/Hesitation - Honda-Tech
honda-tech.com/honda-accord.../acceleration-bog-sputter-hesitation-279...
Jun 11, 2010 - 1990 Honda Accord Ex F22 209000 miles, recent alternator change When I ... When I take off from a stoplight I get a little hesitation/bogging/sputteringfeeling until about 2,000 RPM then ... My 1999 Accord had a similar problem (F18B2engine). ... It only lasted a second or so before it would actually rev up.
What causes a 1993 seadoo engine to bog down then take off, then bog down?
fuel mixing issue. A good tune up is recommended. Focus on the carburetor.
1helpful
91 crx spitts and sputters and bogs out when i go to accelerate
you need a tune up new wires plugs car and rotor and do the air and fuel filter to. after it will be like a new car and the fuel savings will pay for the parts
Sputters
check spark plugs
examine the ht leads, ht caps
check the fuel filter and fuel tap,
next would be check the carbs for sticky floats,
let me know how you get on with that
Feb 13, 2013 • Motorcycles
What would cause 01 ram 2500 v8 to sputter and
cateletic convertor, And a bad timming chain
1998 Pontiac Bonneville SE 3.8L Backfires/ Sputters
sounds like the ignition module is going bad.
2helpful
Top Jaguar Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Denis Houle
Are you a Jaguar Vehicle Part and Accessory Expert? Answer questions, earn points and help others
