Fine food particles are left on the glasses, inside the upper walls of the unit, we've tried gel and dry detergent, extra detergent, adding rinse agent, small and large loads
New detergents work moderately at best, due to changes in epa clean water requirements. we've found that using a small plastic container in the top rack (approx. 1/3-1/2 cup) filled with white vinegar at start of cycle, allows a nice boost for the entire cycle. one of our sons and us as well, bought new DW's and found they cleaned kind of poorly. i found this solution online and we've both gotten better cleaning results!!
Make sure the filter inside the dishwasher is cleaned out and read about my advice for dishwashers for more tips.
<a rel='nofollow' href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
