Computers & Internet Logo
Jim Mattson Posted on Jan 29, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP Elitebook and Apple Extreme wireless connection isssue.
My wirless connection drops about every 10 minutes while using my HP Elitebook 8470p, wirelessly connected to my Apple Extreme Router, while using my Cisco AnyConnect VPN client. I do not experiance any connection issues conected via wired LAN.
Waston Ven
Level 2:
Sergeant:
  • Computers & ... Expert 205 Answers
  • Posted on Oct 09, 2018
Waston Ven
Level 2:
Sergeant:
Answers
205
Questions
Helped
68631
Points
840
Apple Router is a good product of the Apple brand because this brand is very popular between users, its have great features with the latest technology. Apple produces different type products like Laptop, Desktop, iPod, Watch, Router and etc. It also provides support service for the users help, if Apple Router users faced some problem and they want to need support for the solution contact Apple Router Customer Service Number by just dialing our toll-free number which available 24*7. There are expert technicians ready for your help through the pickup call or online connected.
ServicesNumber makes your quest FAST PERFECT and INFORMAL
Peng Xiong
Level 2:
Sergeant:
  • Expert 236 Answers
  • Posted on Feb 02, 2013
Peng Xiong
Expert
Level 2:
Sergeant:
Answers
236
Questions
Helped
52990
Points
599
You may want to see if you are able to change the preamble on computer and the router to use short preamble. If you are using Windows you can go to the network connections to check the advance properties of your wireless card. As for the Apple Airport Extreme you will have to contact Apple for information if your router can change the preamble.
4 Related Answers
A
Anonymous
  • Posted on Nov 13, 2007
SOURCE: vpn pass through problem with us robotics model 5461
solved the problem. Had to set DSL modem to bridge mode and then set the router PPoE, provide ISP name and password information and bingo! works!!
izzydog
Anonymous
  • 38 Answers
  • Posted on Feb 09, 2008
SOURCE: Cisco VPN Client won't connect
You'll want to enable the VPN transparency. In the router's administrative web interface, click the Security Tab, then the VPN Passthrough sub-tab. Cisco VPN's usually use IPSEC, so enable the IPSEC Pass-through and click "Save Settings". If this doesn't work enable the PPTP Pass-through as well and give that a shot.
Anonymous
  • Posted on Mar 17, 2009
SOURCE: VPN problem with Dlink DIR-300
Update your firmware to the latest. I had the same issue and the issue is gone after the upgrade.
Anonymous
  • 160 Answers
  • Posted on Aug 26, 2009
SOURCE: Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
How do I find out if my HP Elitebook 8470p has bluetooth?
well that is simple, in concept
the Bluetooth on this series has 2 kinds of ways.
the most common is, Bt IS PART OF THE WIFI CARD
AMAZING IS, THE FACT THAT THE HP, SERVICE GUIDE COVERS ALL THIS AT HP..COM, HP DOT COM.
A COMPLEX URL, NO?
I OWN 8540W So know them well
the card BT is a seperate card here, narrow. and has its own socket, see them used on ebay, just by one .
now the gotcha
it has special cable so if your PC never had BT ,yes you need the cable too..
seen here clearly
https://www.manualslib.com/manual/1123083/Hp-Elitebook-8470w.html?page=81&term=Bluetooth+Module&selected=1#manual
How do I disable the mouse pad on elitebook 8470
Hi just double hit on the little hole on the upper left of the touch pad. This one will light orange when disabled. Regards.
Go to Start/Accessories/System tools/System info/Components/Network
If you have a bluetooth adapter it will be there.
Need to re-enable touchpad on hp elitebook 8470p
Is there a little orange led on the upper left corner of the touchpad ? If yes double tap on it to enable the touchpad.
My docking station ethernet lights are flashing
You might not use the correct Power AC adapter. You have to use a 90W for standard or 120W for advanced docking station.
Elitebook 8470p not displaying to remote monitor with KVM
Is the laptop actually detecting an output when the KVM is plugged in? Try forcing output with Windows + P (Vista/7) or a function key (not sure what it is for the 8470p).
47helpful
2answers
Need to disable touchpad on hp elitebook 8470p
Hello
You just have to double tap on the little spot on the right top of the touchpad.
It will become orange. To reactivate it you have to do the same.
Regards
4answers
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Grand Canyon Tech
Grand Canyon Tech
