Like i said it runs through all the wash gitate and rinse cycles but will not do anything on the rinse & spin. the belt is still on everything and everything underneath still is moving the way it did when the washer worked completely functional....ny suggestions?
You really still have a belt model? that unit is close to 30 years old now.
anyway if the unit looks like all is moving, then you may have a bad lid switch or most likely an open coil on the wig wag assembly.
it is the part the has 2 coils on a metal bracket on top of the transmission. it moves back and forth when the unit is running.
does it drain but just not spin? if so then you could just have a broken wire to the wig wag or the coil could be bad. wires do break to the wig wag , but you usually hear the coils engaging then shutting off if the wires are bad. so check the coils and try to replace the wig wag second if you dont find a bad wire.
