Need to find date of mfg. so I can order bags. The bags I have found on OE say units built 2009 or later.
SOURCE: How do I connect upholstery cleaner to Kirby Sentria
Here is a link to available owners manuals...
http://stores.shop.ebay.com/CLICK-HERE-FOR-GREAT-DEALS_KIRBY-OWNERS-MANUALS_W0QQ_fsubZ7656839QQ_sidZ122982163QQ_trksidZp4634Q2ec0Q2em322
Hope this helps,
Marci
SOURCE: Kirby Sentria vacuum -- can't figure out how to hook up main hose to vacuum floors
First you need to press the foot pedal for the height adjustment all the way down to lift the front of the vacuum off the floor. On the front top of the vacuum where the LED lights are is a cover. That section will lift up by lifting just below the LED's. Once it's lifted up there are some visual instructions, but here's what they are saying. The little circle on the front divided with the word KIRBY is the belt release. The section of the circle with the word on it will pull out. Like a wind-up flashlight it will turn from lining up with the green arrow counter clockwise 360 degrees and lining up with the red arrow. This takes a little pressure to turn it. Now just above this circle, under the LED bonnet, there is a lever that holds this whole front end on. It must be turned also counter clockwise to remove and front then slips off. The reverse would be used to put the beater roller portion back on. Also this would be the way to slip on the hose attachment to **** through it instead. I hope this is a little clearer.
SOURCE: What year was the Kirby vacuum sentria G10D made
Check the serial number. Teh second and third numbers are the year it was manufactured. The first number is the quarter of that year.
Use bags for made for the G10.
