Caliber Gamo USA Hunter Elite .177  Air Rifle with 39x50 IR Scope Logo
Don Rhoads Posted on Jan 29, 2013
Gamo Hornet schematic
I was given a Gamo Hornet .177 air rifle in a box in pieces. Where can I find the schematics or directions to assemble?
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Feb 02, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
Helped
5548
Points
29
The best thing to do is go on the internet and type in the company name.And see if they have what you need.Or maybe they can tell you who to contact for the schematics and directions to assemble it together.Hope this helps you out.Joseph A Bagli.
2 Related Answers
Mark Campeau
  • 44 Answers
  • Posted on Jan 13, 2010
SOURCE: how to fix jammed clicker on air rifle scope
Sorry to tell you but the crosshair adjustment is more than likely broken. Take it to a qualified gunsmith and he can check it out for you.
Hope this helps, Mark the Gunsmith
Please leave feedback, Thanks.
Testimonial: "thanks mate "
Anonymous
  • 3 Answers
  • Posted on May 13, 2011
SOURCE: the air rifle i have
once the oil burns off and leaves the barrel, try diff pellets as they do make a world of difference. i have a gamo shadow and use promatch. there are some better and more expensive ones but i have no issues hitting a 50c coin from 50m away. breathing, posture, your steadiness and your familarity to the trigger breakpoint all affect your accuracy.
I can't get my gamo whisper mach with a 3×9 sighted in, I've had it about a year and used several different 177 pellets and still can't get it sighted in.
Ok, set your air rifle in a Vise.
Take a target, look down the barrel of the air rifle and move the target until it is centered on the hole in the barrel.
Adjust the sight until it is centered on the target.
After that the only thing that you need to do is adjust for the range (distance/elevation/vertical setting) of the target.
Regards
Geoff
Jan 08, 2020 • Gamo Optics
Can i but a new barrel how much
Bone Collector .177 and .22 cal special edition air rifles ...
www.gamousa.com > Air Rifle
The "BONE COLLECTOR" .177 and .22 caliber air rifles. ... blast reducer integrated into a bull barrel, and utilize the advanced IGT (Inert Gas Technology).
images for Bone Collector .177 Caliber barrel
2answers
Where can i find a owners manual. i bought it cheap from a friend but have no manual to it
http://www.airrifleshop.co.uk/Airgun%20manuals.htm
Has some gamo manuals not the specific one you want but has all the important info for safety and operation plus zeroing if its a parts diagram you want look at the following link
http://www.aceros-de-hispania.com/MANUALES-DESPIECES/DESPIECES-CARABINAS-GAMO/despiece-silent-stalker.jpg
Where is the serial number on a whisperer fusion
I have a similar Gamo air gun and the serial number is on the barrel on a flat spot on the side near the hinge.
The magnification adjustment ring on my Gamo Whisper worked fine at first, then was stuck between 3X and 5X. Now it is free again but the scope is not focused on the 3X and 9X settings, but is clear on 5X...
I'm not familiar with the scope, is it an air rifle scope? One stroke type? If not, the backwards recoil of the air rifle is tough on a normal scope, they aren't made for that type of abuse. They work fine with a normal recoil. That is why they started making air rifle scopes. I'm sure that the internals of your scope are damaged somewhat, you can take off the eyepiece no problem, you might find something in there, loose screw, missing screw, you never know, don't get too carried away with the dis-assembly, you'll never get it back together. It sounds like the magnification ring is messing with the focus of the eyepiece. Might just need some oil. Hope this helps.
1helpful
Top Caliber Optics Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Caliber Optic Expert? Answer questions, earn points and help others
