Hello allisonarena - Try
reprogramming the dryer by either unplugging it or flipping the household
circuit breaker off. Wait approximately ten minutes and then turn on the unit.
If issue persists, then the dryer may possibly be experiencing more serious
issues such as; wiring failure, faulty control board, thermal limiter, or
defective door switch. I would recommend
connecting with an experienced appliance repair tech to assist further and to
reduce the risk of unnecessary parts.
Hi Brian - I understand that your dryer lights are turning on when not being in use. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately two minutes and turn on the dryer. Select a normal cycle and verify if the lights continue to flash. If the issue persists, then it could possibly be a communication error with the main control board, or a potential wiring failure or faulty door lock assembly. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
Hello Kenneth Joynt - Often when a dryer will not stop running, it is because the unit may have a potential wiring failure, faulty timer, or a communication error with the main control board. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If issue persists, I would suggest contacting an experienced service technician to determine the precise cause.
Hello guysmith2146 - Try reprogramming the dryer by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, restart unit and select a normal cycle. Have you recently cleaned the lint screen/filter? Otherwise the dryer may possibly be experiencing more serious issues such as; wiring failure, faulty control board, thermal limiter, or defective door switch. I strongly recommend contacting a local professional to proceed further, should all troubleshooting measures fail. You can often locate qualified servicers by visiting the manufacturer directly.
Hello everclavel - Try reprogramming the dryer by flipping the household circuit breaker off or unplugging it. Wait approximately ten minutes and restart unit. If it proves to be ineffective, the dryer could possibly be experiencing a communication error with the main control board, wiring failure, or faulty door lock assembly. Connect with a certified technician to move forward accurately to assist with the repairs.
Hello Anne Truhlar - Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately 30 seconds and turn on the fuse for the dryer. Turn on the dryer and select a normal cycle. If the dryer continues to overheat then I suggest contacting a professional to accurately diagnose and repair the dryer. The unit could possibly have a defective control board, power supply (240V), heating element, sensor or high limit thermostat.
The thermistor monitors the exhaust temperature
and cycles the high-limit thermostat on
and off to maintain the desired temperature.
1. Turn the dryer off but keep the electrical
supply connected.
2. Make sure that the dryer is empty and that
the lint screen is clean.
3. Close the dryer door.
4. Select Heavy Duty, Timed Dry, More Time
or Less Time, End of Cycle Signal (Louder)
and Start.
5. If error codes E1 or E2 flash on the display
after 1 minute and the dryer turns off,
the thermistor, or the wire harness, is either
shorted or open. Check the wire connections
at the thermistor or the machine
control electronics board. If wiring checks
okay, replace the thermistor.
6. If the dryer seems to operate normally, remove
the exhaust vent and start the dryer.
7. Select the desired temperature cycle to be
tested, and select 20 minutes of Timed Dry
heat using the More Time or Less Time
pushbuttons.
Error codes. are any of these lit?
PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display.
E1 Thermistor open Replace thermistor if found defective
E2 Thermistor shorted Replace thermistor if found defective
Here are the source codes that pop up on the dryer with the "fix"
