Mitsubishi WS-55511 55" Rear Projection Television Logo
Posted on Jan 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WS-55511 code 22.
I'm getting code 22. Short protected.
I assume that means there is a short somewhere?
Any guidance?
Thanks
Phil
  • droptopfox90 Jan 31, 2009
    that would cause my code for a short? Ill check them
    do you know what part number I need to order for the fuses and IC?
Sonny Berry
Level 3:
  • Mitsubishi Master 8,617 Answers
  • Posted on Jan 31, 2009
Sonny Berry
Mitsubishi Master
Level 3:
Answers
8617
Questions
Helped
1723283
Points
23750
Check these two green pico fuses F9A04 and F9A05 to see if they have continuity, if they dont have continuity the Convergence iC and those two picos will need replacement.
  • Sonny Berry
    Sonny Berry Jan 31, 2009
    Yes those are the most common components to cause that in your model.
  • Sonny Berry
    Yes there is only one IC in your model its a STK393-110 IC and the two pico fuses are both 5 amp picos. You can get the IC and the pico fuses at the following ink, and they provide free installation instructions with pictures so you can do the repair yourself heres the link.
    http://servicemanuals.vstore.ca/
Mitsubishi WS-65511 Projection Television won't turn on.
Question edited for clarity. 'make model (what it is)'.
Question moved from Cell Phones category.
12 ----------- indicates no error
21 ------------- X-Ray Protect circuit
22 ------------ Short Protect circuit
23 ------------- Horizontal Deflection failure
24 ------------- Vertical Deflection failure
https://www.google.com/search?q=Mitsubishi+WS-65511+code+22
Antique technology
1helpful
I have code 22
code 2.2 is short protection and in MItsubishi sets means one of the pico fuses is blown and the problem is in the Convergence circuit.
If you require detailed help let me know, this can be a do it yourself repair.
Steve
1helpful
Mitsubishi 5511 getting a code 22 - short protection fault. How
Code 22 points towards a failure in the convergence section of the TV. You can get a convergence repair kit from www.TvRepairKits.com to do the repair yourself.
1helpful
WS-55511 shuts off with in 1 secound when turned on.
See my reply to your last posting---The set needs The Stk-393-110 and whichever of the two pico fuses is blown replaced--I have instructions AND photos of what the fuses look like.
SD TECH
4helpful
2answers
My model is a WS-55511. I turn on the TV, the
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
1helpful
Ws-6580 error code 23
CODE / INDICATES
12 / No error has occured
21 / X-Ray Protect Shutdown
22 / Short Protect Shutdown
23 / Horizontal Deflection failure
24 / Vertical Deflection failure
1helpful
Tv turns on then off
hold the menu and input buttons simultaneously for 5 seconds. the tv will blink an error code
Error Code Probable Cause
12 Normal Operation - No Error Detected
21 X-Ray Protect
22 Short Protect - likely convergence IC failure
23 Loss of Horizontal Deflection
24 Loss of Vertical Deflection
Fast Blink for 70 sec. After AC is applied = Normal - DM μPC is booting up
Fast Blink (doesn't stop) After AC is applied = TV μPC is running, but DM failed to boot up
Slow Blink Set is Off = Normal - Timer is set for Automatic Turn ON
2answers
Mitsubishi ws 55809
22 is short protect usually its the convergence Ics in that model that can short out. check fuses F9A04 and F9A05 if they are open its most likely the convergence ICs that need repslacing. If you need further assistance, please reply to this same post.
2answers
Error code 22 on a Mitsubishi WS-55907 55'' HDTV
your set is the V17 series so a code 22 means short protect. Which means the TV has a short circuit condition and is shutting down to prevent further damage. You can get a manual for the V17 sereis at the following link for 15.99 and they will provide free unlimited support to help you with the diagnosis and locating parts. Your set is coverd in the V17 sereis service manual under the mitsubishi section. Here is the link in case youd like the service manual and free support.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
