My LG shine has gone dead and my wall charger and my usb wont charge the batter, i even borrowed my friends charger and it still doesnt work, i think it might be my phone where the charger connects. ??? plz help?
My LG wont charge either I went to a friends house and used her charger and there is actually charged. But at my house it wont? What is wrong with my phone?? Or is it just a charger? I have gotten two new chargers and they work but now neither of them work it has happened to the same thing? I have to wiggle the charger around then when it says charging i have to hold it there for about 2 hours it is not fun?
The charger port is going bad. It happens over time The symptom of this is you have to hold it into place.
The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.Youcan get an external battery charger to charger the battery separate fromphone. An extra battery is a good idea as well so you canhave one charging at all times. The best and cheapest place to buy a new charger for yourshine is ebay. They run about 5 dollars shipped. Check out thefollowing link for the selection.
Exactly.its the problem of the inlet connections- where u connect the charger.its loosened up internally and is gone faulty.dont push the pin to try charging it or you may damage it more.just go to any mobile repair shop.they will change the inlet of the phone from wher u insert the charger pin.its not at all expensive.
thanks.
dont forget to rate the solution.
It might not be your phone, my friends and i all had similar problems with chargers. sometimes the LG charger gives out and it needs to be replaced. it sucks
Please check the battery charger. Otherwise, I had one of this HP Mini 1000 replaced by HP with the same problem, the Mini gone complete dead, no charging or turn on.
"Change batter pack" means your battery is dead. The camera should have come with a charger in the bok that can plug into the outlet in your wall. It uses a lithium ion battery, so you can't use a regular AA batter charger, for instance. You cannot charge the battery via the usb into your computer.
David Are you leaving the power on while you are charging the Chair? If you are try charging with power off at the joystick. The manufacturers of all power batteries do not recommend charging with automotive chargers. I would try to locate a friend or neighbor that also has a chair or scooter and borrowing their charger for a few hours to see if it will charge your chair. If not contact your provider and borrow a charger from them. If the different charger works then yours is bad. You shoud be able to order a charger through your provider or by calling Pride Mobility @ 1-800-800-8586 Hope this helps you PS I didn't say you couldn't use the "other" charger. But I wouldn't want you to think I approved of it
First you must determine is it the charger faulty or the phone ? , have you a friend with the same phone if so try her or his battery to see if your phone is ok if so try the charger with your battery and see if it charges if it does get a new charger , if it did not charge or work with your friends battery or charger the sorry it would be cheaper to buy a new phone than try to get it fixed ...
if you haven't got a friend with the same phone have a local electrician check if there is an output from your charger . if there is it may just be the battery try a new one if still no luck it is probably the phone's charger circuit gone pop ,, sorry .. vortash
my phone stopped charger and i went to settings and usb connection and go to music sync and then i put it on the charger and played with it for a lil while then it started charging and every since that i never went dead!!
