I need it for my YORK STELLAR PLUS, model: P2UDD06N03801D, serial number: ENCM611969```
SOURCE: Draft inducer blower going bad
I agree close enough. Only slightly slower. If it fits mechanically , useit.
SOURCE: My York Stellar PLUS furnace (Model
Check gas pressure, inspect manifold & make sure there is not a blockage.Make sure gas is present and main gas shut off valve to furnace is on also check the knob on the 24 volt gas valve and see if it is in the on position , check the MV terminal on the gas valve to 24 volt common with a volt tester to see if you have 24 volts present, if you do have 24 volts at gas valve, replace valve. if you do not have 24 volts at gas valve check high limit control & roll out limits for a open circuit, Good luck.
SOURCE: what is the model number for the Draft Inducer
I think you must mean GMP075-2rev8 check this link for parts listing:
http://site.famousparts.com/goodman/PDF/RP-169C.pdf
Johnstone supply which has many locations in many cities sells Goodman and stocks parts, and available mailorder http://www.johnstonesupply.com/corp/Default.aspx
SOURCE: I removed my Fasco 7021-11577S when the bearings
There should be a gasket between the mounting flange of the inducer motor and the furnace. If you do not have that you can use a small bead of blue or red silicone caulking to seal it. Hope this helps you. Thanks
This is not a "tool" question, you should have posted to Air Conditioners.
eBay doesn't list any right now, last one went for $50.
Is it the control board or the fan or both that you need to replace? Might be able to find the control board separate if you have that number.
Best bet if you have the time, is eBay, Craigslist or a local heat and air repair guy who might have an old one he can sell you.
If you are lucky:
Ten-year internal functional parts limited warranty is effective on units installed after October 1, 2001 and manufactured January 1, 2000 or after. Earlier installations have two-year parts warranty
http://www.customengineering.info/products/esxv90.html
