I am looking for a key for javelin cs-100 cash register. Any ideas where I can purchase a key from? Cheers.
SOURCE: Casio Model #PCR-202 cash register
That model is so far out of date it's near impossible to find a manual. You can find some solutions to FAQ here:
http://www.casio.com/support/techsupport/spd/pcr202.html
Other manuals (may be able to find a similar model) here:
http://www.casio4business.com/sa/support/downloads/downloads_manuals.html
SOURCE: CASH REGISTER CASIO CE 3115 DISPLAY E 03 AND ALARM
This ino might help: Cleaning ERRORS: ______________________________
1.- Turn the Mode lock to OFF
2.- Press down the RECEIPT FEED button
3.- Turn the key to PROGRAM
4.- Lift up RECEIPT FEED button (FFFFFFFFFF)
appears on the display panel
5.- Press SUBTOTAL (wait for receipt to issue)
6.- Turn Mode Switch back to REG and use as Normal.
Also another bit goes like this:
RESET: _______________________________________
1.- Insert the OW key and turn to OFF
2.- Hold down the JOURNAL FEED button and turn the key to PROGRAM mode
3.- Release the JOURNAL FEED button. The display should shows "00000000".
4.- Turn the key to OFF
5.- Turn to REG1. The display shows "INIT" and "0.00"
6.-
Press the number 10801 and then press SUBTOTAL. Initialisation is
completed when the printer stops operation. The display shows: "_ 0.00"
Hope this helps in restting to factory settings................................sodeep
Go to a website called:
www.retrevo.com
You can download manuals there.
also you can go to Casio.com and get a manual also
SOURCE: Casio TE 2000 Electronic Cash Register doesn't work.
u mean no power at all?
If yes, try to reset it. (NOTE: This method will RESET all of ur programmed data!)
1. Off power
2. Take out the AA size backup battery
3. On Power
4. The machine should show "0000000000"
5. Fix the AA battery in
6. Program the Date & Time
7. Ok
SOURCE: date setting for cash register casio TE-100
Turn key to program mode.
Type date as YYMMDD
Press X/TIME (maybe labelled X/ DATE TIME)
Press CLEAR
For those of you needing a Casio TE-100 manual, c-tech has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Testimonial: "My problem might be very simple, but, the response is superb.. I'm glad I was asking to the right place.. Thank you very much.."
