Tv have a problems known as a convergence problems,it is dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board reqiured changes it 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board problems to solved the tv picture convergence picture problems.The shop,will cost like $300-350 for parts and labors.
You do have a failure in the convergence circuit of your set. If you are good at soldering you can replace the IC's yourself. They are on the large circuit board on the left side of the set looking from the back, and attached to a large aluminum heat sink. If you don't feel comfortable doing that, I reccomend removing the board and sending it to PTS corp in Indiana. They are pretty reasonable repairing boards, and a lot less than buying a new one.
hi. this will be an easy fix for you if you are a good solder. you will need to replace the convergence chip that is located on the PC board(main). this chip is damaged and it has failed due to this damage that has occurred. click below for your new convergence chip(stk).
Good Day, beekae;
No, there no other adjustments that can be made, the TV has had a Convergence Circuit Failure. The "CCF" is caused by that circuit, please call an Authorized Service Center and get an estimate. The avg cost is about $550.00. Good Luck, big IRISH. PS or come back and I'll tell how to fix, if you are handy and own a good soldering station.
This is most likely a convergence problemand can easily be fixed. If you can solder you can repair this yourself. First try resoldering the pins on the convergence ICs. If that failes to resolve the problem, replace the ICs. THese are large black Ics attached to a heatsink and may be marked STKxxx.
You need to change both convergence ICs numbers STK392-110 you can get replacement ICs at the following link and they provide free instalation instructions with pictures and free on line tech support so you can do the repair yourself. Heres the link. http://servicemanuals.vstore.ca/
